Kontrolled
Which build did you try. Number 1 is pretty much fixed
I'm still having a problem with number 1 as well. Only reason I couldn't stick to the new build.
Sent from my LG-MS770 using Tapatalk 2
5/12 build the newest one on first page... followed directions to a t... like i said this rom is good just small issues messed it up for me the call volume is very low that was the main reason i dropped it after the GPS issue and the picture messaging
I have searched this thread for an answer, if there is one I could not find it. I can not get 4G to work. I flowed Bobz directions in the op's post. But still no 4G. Any ideas ?
Thanks
Using the latest build btw.
Hey everyone.
I am new to the forums, but have been lurking for a while.
I recently flashed bobz rom, and wonder if anyone has a version of the quick memo that will work with CM10.
I actually used that feature a lot, and somewhat miss it.
Also, how does c modem help 4g speed?
And can i just flash it from recovery? or do i need to wipe data or anything?
Thanks in advance. ^^
Thanks johnnyl1111works great now... just miss that 4G in status bar... lol
Just installed the ROM, everything is working great -- pic messages, 4g speeds, not having any of the commonly reported issues except that I can't access my external sd card from in CM10. I see my data when I explore from the computer, but ES file explorer shows it as empty, and the built in CM file explorer refuses to open it and says I need elevated permissions, though as far as I can tell I have root access. Do I need to reroot the phone after installing Cyanogen, or can someone help me figure out what's going on here?
also holding the power button doesnt give me the option to reboot to recovery, only power down, change profile, reboot, and airplane mode.
edit:
I installed a different SuperUser to /system and now ES explorer shows me as having 2 external sd cards, 0 and 1. 1 Is mine with my data still on it, and the other shows as empty and is the phones internal storage.
Its located in storage/sdcard1 i think thas what it says but yeah if u click on external sd it wont take u no where
edit:
Could you post the link to the thread where you found that camera app?First off Bobz you are the reason I still use metro pcs
They are slow with the updates etc, but for the price I cant complain
You made my optimus M bearable
Flashed latest build on F firmware from a stock based rom floating around on here.
Gps finds me with the quickness, my battery life is so much better its ridiculous,I find myself waiting for my phone to run out before i throw it on charger.
I used to have to throw it on charger halfway thru my shift..not anymore
4g speeds are noticeably different as well as wifi,
my only 3 problems 1 of which is solved,
the call volume is whisper quiet
i have noticed a few times after pushing power button for screen lock
the backlight has come back on without image a few times, turning screen on and off again corrects this
The camera does not let you change to external sd to save pictures
by flashing this https://www.dropbox.com/s/0k7fogi5cqixtk2/jb2cam.zip
the option to change location is there
And to fix the blacklight just go into recovery and go into mounts and storage and wipe sdcard and reboot, you don't lose app data or anything.
picture messaging works fine for me
i have no problem with In call volume.
