Developer: Blarf
Builder: BobZhome
Current Version: CM7.1-RC1-MS690-BobZhome (09-5-2011)
People worked with/owe thanks to:
Alex Zepeda a.k.a Blarf - For his great skills on developing for the Android.
reppard & somedood81 - For help with getting need files
What Does Not work?
Screen Animations
Changelog
09-05-2011:
- Fixed: WiFi
- Kernel v5: a)Fixed: Overclocking scaling b)Added: Interactive and Smartass governors c)Changed: video drivers
09-03-11:
- Kernel v4: Make Over Clocking show up in CM settings
09-2(pm)-11:
- Fixed: Notifications Carrier info banner
- Fixed: MMS
- Kernel v3: a)Fixed: Over Clocking b)Switch: to TCP-Westwood
09-2(am)-11:
- Sync'd up with CM
- Updated to Blarf's repo: Camera geo tagging fixed
- Removed Market from build(grab custom Gapps from download area(below), if you want the old market)
- Kernel v2: a)Added: Over Clocking b)Removed: No physical keyboard
08-26-2011:
- Sync'd up with CM
- Initial setup of the MS690
- Removed all languages except English
- Removed FM Radio - OM has no radio
- Removed 2 extra themes - theme chooser/manager is still included
- Removed all live wallpaper, but kept live wallpaper chooser
- Removed ADWLauncher
- Added LauncherPro
- Added old Market(I hate the new Windows 7 looking Market) - If you flash Gapps, it will update you to new market
- Added Darktremor Apps2SD version 2.7.5.2
- Added ringtone added: "Somebody's Out There" by one of my favorite bands: "Triumph"
- Changed bootanimation
Download Links
NOTE: You need to have an ext partition on your sd card with my ROM, because Darktremor Apps2SD automatically moves the dalvik to the ext partition. DO THIS WITHIN CLOCKWORKMOD and be sure to
back up the card to a PC first! It's not necessary to format the card every time you flash a new build.
NOTE 2: If you end up having issues, always go back and try wiping. Start fresh and see if things don't improve.
NOTE 3: It'll take awhile for everything to settle down. Especially after installing gapps and syncing accounts. Give it a few minutes to settle and reboot a couple times. The system will speed up after that.
Build 9/5 :
CM7.1RC1-MS690-BobZhome-090511.zip MD5checksum= 37c6feba65392848f5b5098133bd8118
Custom Gapps(with old version of market):
gapps-gb-20110613-BobZ.zip MD5checksum= ba667e3513c53ae73239e962a0a6cf1a
Latest Gapps:
gapps-gb-20110613-signed.zip MD5checksum= 87ffe96c5e94531d96d018e09c701581
Helpful Tips
Overclocking is available in Settings --> CyanogenMod settings --> Performance --> CPU settings. Tweak it as you like, but know this: not all OV's were created equally.
Builders Notes
All credit goes to Blarf(the Dev)...please donate to his beer fund!
How Can You Help?
Please don't thank me, instead
donate to Blarf for all the great work he has done.
Future Versions
Fixing Screen Animations
