mystifire2
Mine builder runs flawless testing Spyro the dragon on fpse shortly
The mic issue is a known problem that is being looked into...
You have to understand that when companies like LG release source code, they don't have to release drivers. The drivers we are using are from FRO-YO, yet you are running GingerBread with this ROM. Developers do the best they can to get things to run as good as possible. More than likely the mic and screen lag will be an issue until a phone with similar parts as the Optiums comes out with GingerBread pre-installed from LGUntil then, be happy your phone is running an OS that most new phones don't have yet
Enjoy,
Bob
That "roaming indicator off" is going to be the death of me...lolJust flashed the rom and its pretty smooth so far.. gonna play with it a little more to see other stuff.. no screen lags now.. but the banner still says "roaming indicator off"
The option for reboot recovery is not working.. just reboots when u select reboot recovery
n just may try it this week
It's nice being able to use the phone with the "Screen Animations" ON
Enjoy,
Bob
Developer: Blarf
Builder: BobZhome
Current Version: CM7.1-RC1-MS690-BobZhome (09-9-2011)
People worked with/owe thanks to:
Alex Zepeda a.k.a Blarf - For his great skills on developing for the Android.
reppard & somedood81 - For help with getting need files
What Does Not work?
You tell me
Changelog
09-08-2011:
- Kernel v6: a)Optimized b)Changed video drivers
09-05-2011:
- Fixed: WiFi
- Kernel v5: a)Fixed: Overclocking scaling b)Added: Interactive and Smartass governors c)Changed: video drivers
09-03-11:
- Kernel v4: Make Over Clocking show up in CM settings
09-2(pm)-11:
- Fixed: Notifications Carrier info banner
- Fixed: MMS
- Kernel v3: a)Fixed: Over Clocking b)Switch: to TCP-Westwood
09-2(am)-11:
- Sync'd up with CM
- Updated to Blarf's repo: Camera geo tagging fixed
- Removed Market from build(grab custom Gapps from download area(below), if you want the old market)
- Kernel v2: a)Added: Over Clocking b)Removed: No physical keyboard
08-26-2011:
- Sync'd up with CM
- Initial setup of the MS690
- Removed all languages except English
- Removed FM Radio - OM has no radio
- Removed 2 extra themes - theme chooser/manager is still included
- Removed all live wallpaper, but kept live wallpaper chooser
- Removed ADWLauncher
- Added LauncherPro
- Added old Market(I hate the new Windows 7 looking Market) - If you flash Gapps, it will update you to new market
- Added Darktremor Apps2SD version 2.7.5.2
- Added ringtone added: "Somebody's Out There" by one of my favorite bands: "Triumph"
- Changed bootanimation
Download Links
NOTE: You need to have an ext partition on your sd card with my ROM, because Darktremor Apps2SD automatically moves the dalvik to the ext partition. DO THIS WITHIN CLOCKWORKMOD and be sure to back up the card to a PC first! It's not necessary to format the card every time you flash a new build.
NOTE 2: If you end up having issues, always go back and try wiping. Start fresh and see if things don't improve.
NOTE 3: It'll take awhile for everything to settle down. Especially after installing gapps and syncing accounts. Give it a few minutes to settle and reboot a couple times. The system will speed up after that.
Build 9/9 : CM7.1RC1-MS690-BobZhome-090911.zip MD5checksum= 85129acb25b444b5d6151cdd90fe2c36
Custom Gapps(with old version of market): gapps-gb-20110613-BobZ.zip MD5checksum= ba667e3513c53ae73239e962a0a6cf1a
Latest Gapps: gapps-gb-20110613-signed.zip MD5checksum= 87ffe96c5e94531d96d018e09c701581
Helpful Tips
Overclocking is available in Settings --> CyanogenMod settings --> Performance --> CPU settings. Tweak it as you like, but know this: not all OV's were created equally.
Builders Notes
All credit goes to Blarf(the Dev)...please donate to his beer fund!
How Can You Help?
Please don't thank me, instead donate to Blarf for all the great work he has done.
Enjoy!
Format everything except SDcard and re-flashWhen I flash this my screen shows up as inverted colors..
Yes, compiled with kernelUse my eri.xml file man you can make the banner say whatever you want! Where did you get the updated drivers from? Compiled with the kernel?
porlly the same one in the metroffYes, compiled with kernel
Extract this file: VD_Drivers.zip into ~/android/lg/MS690_kernel/drivers/video/msm/
Happy building
EDIT: What eri file?
Is your phone new?I did that...
Is your phone new?
start terminal and type:
su
then type:
dmesg | grep novatek
then type:
dmesg | grep hitachi
Let me know which command gave you back info and which command yielded no output.
Thanks,
Bob
k, that's good...I thought you may have a new phone with a different screen on it.The novatek one worked for me
Holy crap someone else has the boner phone this time and its not me!
My phone is loving the new drivers!
Nice build Bob.
-_- referring to me? Lol
Sorry... got excited, didn't mean to rub it in, I know how it feels...
