Root [ROM][WIP]CM7.2.0 RC1-BobZ
Hey Bob I checked my screen like you asked in Repard's release and I have the Novatek screen not the Hitachi and I can't get his rom to work cause it stays at a black screen. Just wanted to let you know.
Getting a lot of reboots with the latest build. I did a complete wipe before flashing and I'm only running at 728. This is the first cm7 rom I have had reboot issues with and all the previous builds didn't have an issue. Also flashplayer was installed as a system app but it didn't work, I had to uninstall and reinstall it to get the browser to recognize it was there.
Thanks for the info!
I may have gone overboard with the scaling, I believe that may be your rebooting issue, I'll lower it in the next release.
The flasher player may have got installing before the browser, which may have been why you needed to reinstall it. I'll have to look into the pecking order with that.
Bob
Bob
I think flash should be installed as a user app. Install it from the market/xda etc, then check n see where it installs too. ;)
Bob
Yup my phone is one of the crappy ones that only runs 729 stable, I switched to 600 and it stopped rebooting.
Updated to build 9/16...hopefully Playfulgod's eri file fix's the "roaming indicator off" issue!
Bob flashed over 9\11 build (no wipe) Still :(roaming indicator off
(clean wipe) fresh flash 9\16 build still :(roaming indicator off
My phone has been acting strange the last few days (lagging, no call alerts, other crazy shiz) and today I was poking around and noticed a crapload of dalvik-cache folders inside the main one with files in each. I wiped cache and dalvik and hope that fixed the problem. Just wondering has anyone else seen this on their phone?
Example /cache/dalvik-cache/dalvik-cache/dalvik-cache/dalvik-cache/ etc.
I seem to be having issues with my blue tooth now on the latest version. It will find it connect for about 3 seconds then go back to connecting again. Tried re-flashing and doing a 100% wipe and reinstall of rom and still same issue.
Updated my ROM...Info on OP(first post)
I removed the MMS hack, it does not work right and/or not at all. I'm going to work on getting it to work correctly like every other ROM. Please test the MMS before flashing the hack.
A new lock screen widget: Rings. You can see it in action here
Enjoy,
Bob
As far as the Adobe Flash hack. Is that just the actual flash package? Meaning I can just reinstall the hacked Flash for ARMv6 package and it will work?
