Um, my camera is inverted... it hurts my brain to even try to use it, lol...
Yes, compiled with kernel
Extract this file: VD_Drivers.zip into ~/android/lg/MS690_kernel/drivers/video/msm/
Happy building
EDIT: What eri file?
ok so i flashed playfulgods newest version , everything is perfect, the screen animations work and all. i just dont understand why this rom wont work...?k, that's good...I thought you may have a new phone with a different screen on it.
I'm not sure why your screen is inverted, try PlayfulGod's version to see if you get same results. Reppard will probably post a new build either tonight or tomorrow...he now has the secret ingredient for his recipe
But if I was a betting man...I believe you may have issues with the new drivers that fix the lag issue.
I didnt use the drivers bob n reppard did, I just enabled msm_logook so i flashed playfulgods newest version , everything is perfect, the screen animations work and all. i just dont understand why this rom wont work...?
playfulgod do you know why my screen shows up as inverted colors like your first version of the 9-7-11 version of your rom?(that you fixed)
I didnt use the drivers bob n reppard did, I just enabled msm_logo![]()
Probably did...I'll revert the video drivers and fix the camera with next build.And that helped my screen from being all funky colors?
grab the one from the ascend buildThat roaming indicator hates me...I even used Reppard's eri.xml file!
One bad thing is the battery life.
Did you Calibrate your battery after flashing the rom? They say you should do that after every time you flash a rom.
^^^ works for me everytime - great battery life with calibrating![]()
I have a2sd pre-installed, so it probably put your keyboard in the ext partition. Just move it to your phone and it will work fine! If you have an issues or FC with an app, 90% of the time you can fix it by moving it to the phone. Try to keep system apps, widgets, keyboard, and apps you use every day on your phonealso mjust flashed this last night, tryed downloading swipe and noticed that the Unknonw sources thing wont stick!!! is there something i missed? other that that, my phone is way doper than when i bought it!!
also, my mms wasnt working, so i flashed reppards MMS fix and it now works!
Bob
Is your phone new?
start terminal and type:
su
then type:
dmesg | grep novatek
then type:
dmesg | grep hitachi
Let me know which command gave you back info and which command yielded no output.
Thanks,
Bob
On the OV(Virgin Mobile version) the Hitachi screen doesn't boot(stays black).Mine responded to Hitachi so... What effect would it have using your ROM? I have had it got awhile and haven't noticed anything yet that's drastic.
Sorry for double post if a mod can merge please.
What ROM are you using?
Thanks for the info...I believe you just help me solve an issue with another phone!Yours. Haven't flashed the newest version yet though.
