Would be pretty cool to see the Android Nyan Cat remake from ICS though lol. Anywho, rom running smoothly. Very Stable, the mms fix works now
no need to delete the Telephony.db or get apn settings
Love it!.. Well thats for me in this case.
Make sure permissions are set right on market using root explorer. I had a problem with market as well. Until I grabbed the vending.apk put it in system/app/vending.apk
It would not allow me to install for some reason. Oh well. I'll just wipe-upgrade-and reflash gapps.Please realize it is not only my ROMs/phones having these issues. A quick Google search will show you it's a Market issue on many different phones.
In terminal emulator try this fix:
su
cd /cache
mv download download.old
mkdir -p /sdcard/cache/download
ln -s /sdcard/cache/download download
Okay, so I did some further investigation on my problem. It turns out I was completely taking up the internal storage with all my apps not my messaging. Thus the result of the great slow down. This time upon upgrading to the ROM released on 1-5-12, I installed all my apps to the SDCARD except my home, GO SMS, and many others because when my home was put on the SDCARD it put me in a bootloop somehow by the fact it couldn't load my home before mounting my SDCARD. Everything is still super zippy, and I try to keep EVERYTHING away from the internal storage. But now I have a problem with Market, I did the MarketFix app but not my market gives me "invalid package file blah blah." And I cleared the Dalvik, market cache, and the market data. Nothing. But I deleted the market by accident trying to fix it. And now it just does not work upon re install it crashes left and right. So I hope there will be a fix for this? And then the MMS patch did nothing for me. These are the only problems I have encountered thus far. Everything else is great! I will be upgrading to the lastest ROM tonight and reflashing GAPPS to fix the market crashing. Thank you everyone! Thank you Bob! ^^
Are the mms working with out any patches?
What is left to be fixed on this rom?
I have personally added a bunch of features to my CM7 rom. A few of the new features will be in CM9, but I have included them in my CM7 build.
Enjoy,
Bob
Enjoy,
Bob
no, to get them to work I had to flash the metroff.zip and change the apn password
how do you change the apn password?....
thank you mario i got my picture messaging working now... A question for anyone who can help me, my cache folder only has 5.93mb free of memory and i found out thats the main reason it fails to install apps is cuz it has low memory in the cache folder. now my question is is there a way to move the files from there to the sd card or sd ext or any other part of the phone my internal memory is 201mb free system rom has 106 free sd card 13.6gb free and sd card (a2sd)426mb free the only thing that gets full is the cache folder that has 61.32mb total and 5.93mb free any help would be great thanks in advance
ive used that app but it doesnt clear the dalvik cache and if you do clear it nothing works plus cuz the apps use thos caches to run so i think i need to find a way to move them to sd ext thank you for the respones though![]()
