mario0318
Ive tried everything and I still can't get mms to work
Which MetrOff.zip file did you patch? I used this 1.3 version (attached)
Just to be sure you did all these
- No other SMS app has taken over function for MMS
- Patch that MetrOFF file in recovery
- Open APN and set password (click menu and Save to confirm changes)
- Selected the APN radio button to enable it
- Deleted telephony.db
- Reboot
- See if you're getting a reliable 3G signal (or 1x if you're still on it)
At the very least I had an issue where MMS wasn't working for a couple of recipients but it may have been a MetroPCS server side delay because after a few minutes I was able to receive and send messages just fine.
Im just throwing this out there but it could also be a PRL issue, where you may either have to update or revert to an older one depending on your location. If you do have a newer PRL, double check in your CDMA network preferences that CDMA/EvDo are selected.
For now I'm out of ideas regarding fixes on Bobz ROM.
