alfick3
Android Expert
Any body have issues connecting to their wifi? :/
Not me. I can connect at home and at my local Starbucks. I haven't tried any where else though.
what you sayin does not sound like evdo signal problem, but a authentication problem.
does the phone connect using 1x?
Ok, one thing I have noticed. It's just a minor thing really, but a bug none the less. I have the lock screen sounds setting checked, but yet when I lock the screen, it doesn't make the clicking sound, or any other sound for that matter, that i'm expecting.
Actually it does, you just have to hit the sleep button from the status bar Widgets when you wanna lock your phone. Found this out last night. PS, you have to add it from cyanogen mod settings > interface > notification power Widgets.
Some one asked about battery life in an earlier post. I had mine plugged in most of the day, until about 4 pm. I then unplugged it and went to work. While there I used it a little bit, but nothing very strenuous. It's now 8 hours later and I am only down to 59%.
if your getting connected using 1x then your athentication should be good, I dont know what else you could do, you may try different locations.how could i fix this?
Eh owell guess I'm just gonna break down nd buy the indulge on friday :/
The overclock kernel that we used on the GBCM7 beta seems to be what is causing wi-fi connection issues....however, I switched to the "any rom" r.o.ck. kernel (sense rom users typically use this one) and I've had astounding results including a much more stable device!(The mms patch works with this kernel as well!!!)
And yeah...here's how to change kernels without wiping your rom.
Follow these steps closely!!! (READ EVERYTHING BEFORE ATTEMPTING THIS)
1. Place the new kernel zip on the root of your SDcard or somewhere you can easily find it in recovery.
2. Reboot into recovery
3. WIPE the Dalvik Cache
4. Wipe the Cache
5. Disable signature verification
6. Find your new kernel, flash, and enjoy
Note that when wiping the Dalvik cache that it takes longer to boot the phone back up as the Dalvik cache has to rebuild. Expect to be watching your bootanimation for several minutes. For those who wish to install the mms patch; this cannot be done until the phone reboots after installing the new kernel!!!
Good Luck!!![]()
Has anyone had problems with gmail sync or with message updates from the phandroid app on this rom?? I literally have to hit refresh or resync everytime I check those apps.
4. Wipe the Cache
Good Luck!!![]()
To answer your question, I personally haven't had any problems getting gmail or phandroid either.
No you better not Get the Lg Esteem that comes out soon![]()
