Scur
Android Expert
bobz has change mac addy for 0701 and 0708 and they connect fine with my router, both phones can be on at the same time with no issues, you might want to give your router a reboot, or you might need to change the channel or your router depending on what router you have.
Now that you mention it, I was having similar issues with Netflix on GoogleTV which were solved by turning everything off, letting the router reboot, then letting the Revue reboot. I'll flash PG's again, and try it.
anyway...
but sadly my benchmark isn't that low..
