Reddlocks10
Dial *228.If that doesn't help,by all means,dial 611 & talk to a customer service rep.They should be able to resolve your SMS/MMS issues.
Would flashing Bobz 0701 make a difference?
nope. but it cant hurt to try or reflash what u have.Would flashing Bobz 0701 make a difference?
yes your sd card needs to be partition so the dta2sd will work, make sure you have a class 4 sd card if you planning on moving the dalvik.![]()
Hi, thanks for reply. Now can I just ask before the partition do I need to format my card?
Also, will dta2sd be automatic or do I need to do something else? When I first flashed I was just so happy I did it that i didn't find out about all of this I just start moving user apps to the SD. Should I move them all back before I partition card. I'm such a Noob![]()
just partition and it will do the rest...![]()
Thanks Nuttmeg, you have been very helpful to me as well as many other noobs from what I have seen here in the forum, very cool. Your posts are very informative and have totally helped me pimp my phone.lol! Seriously, i really appreciate all your advice. You' re one the most knowledgeable members (hence the guide title). I'm really glad to be a part of this community, I've learned so much and I'm still learning more everyday
Does anyone know how to make the status bar brightness work on cm7? I have it enabled under interface tweaks but when I slide my finger across it nothing happens. Is this not working for the ascend or am I missing a step? I would really appreciate your help!
It doesn't work very well on my phone either,only once,& all it did was dim it all the way down & would not increase brightness.
Probably another one of the infamous ASCEND ANOMALIES due to varying hardware from phone to phone.
I'm not sure why my phone has a battery problem with cm7. I only get several hours on CM7 and switching back to stock I get 3 days. I know that I'm not the only one with the problem though, you will see if you do a goodle search.
another reason for my switching back to stock is that I really like the stock apps, launcher, mms, call, and contacts and I cant find a way to install them.
your welcome, glad everything is working out for you, now where is them Cookiesjust kidding...
new build available:
cm7-ascend - prepaid android
note: Nuttmegg could you please sir update the op.
Thx bro![]()
cough yup, and a good boot animation...cough, lol
most any that you find will work, you just might need to edit the desc.txt in the bootanimation.zip to 320 480. I do this inside of winrar w/o extracting it.Is there a place where I can d/ld other boot anime's that'll work with the Ascend?
New build available:
CM7-Ascend - Prepaid Android Also avail through ROM Manager.
NOTE: nuttmegg could you please sir update the OP.
Thx bro![]()
Thanks, and on this build yes, just download and flash the 748 Kernel for this and the 0618 build.Love the new boot animation! You rock bro. Is their anyway to OC my Ascend to 748 with this build? I love your CM7 builds it just drives me crazy that I cant get my GPS to lock.
You're welcome and thanks. About to post a RC1 build tooThanks for the new build.. In no ways am i complaing about something new to flash but i finally broke down and went to 0624 yesterdayJust sayin thanks.. will check it out soon..
You're welcome and thanks. About to post a RC1 build too![]()
the one for 0521 - 0624 will work on the new buildThat rocks! I went to the Wiki and I dont see any links to download the kernel. I see 2 links one says its the isaacj87's original and the other is 748Mhz oc kernel for 0521 - 0624 builds. Then it says Note: Dont not use the overclocked kernels on any builds after 06242011!!!What to do?
What size partition is needed for this to work right? Also, I'm thinking maybe I should move the apps back from SD to internal first since partitioning erases the SD card. What do u think? I read on anther site that it may be better to wipe everything first then partition the SD then reflash the rom. Is that really necessary? Sorry for all the questions I am still feeling a bit confused![]()
the one for 0521 - 0624 will work on the new buildlong as your Ascend can handle it
When I wrote that I intended on my next build being RC1 which will be going up here in a lil while![]()
