PlayfulGod
Extreme Android User
sumtin is brokeded reflashand everytime i try to connect to usb mounting my phone restarts any help wit this??
soon as I find out how to fix whats causing wifi etc not to work.when is the next build coming??
Very excited! I finally flashed cm7 Successfully! I am running Bobs lazy build. However, I was wondering if there is a way to overclock past the 672? I want to see if my phone will handle a little more. Thanks.
also my signal bars are really low or sometimes not even there now after flashing. Is there a fix for that? Thanks again!![]()
*228 option 5 than option 1 if your on metro for the latest roaming list!!!![]()
not quite, but the file on the phone determines what towers it looks for. That goes for all cell phones.Wait. You mean my phone decides whether or not I'm roaming according to data saved on it?
slide your finger across the statusbar.Does anyone know how to make status bas brightness to work? I enable it under status bar tweaks but it wouldn't do anything![]()
There is a another Bob's one that can do 710mhz.
chances are if your phone wouldnt boot my 0624 it wont boot bobs 710 version either.Ok, so that means I would have to flash the 710 build to get higher CPU. My phone still seems so slowCan i use setcpu to go a bit higher without having to reflash? I boot looped when I tried to flash 06242011. Do you think Bobs 710 will work? Maybe my phone could handle like 691 or by some miracle 710!
mine has a blue android screenlets say you are getting 1 bar to none and you need to get good signal from a closer tower, and a way to get that good signal will be updating your PRL.
If you tried Bobz and playful build and it got stuck on the red screen than your phone would fall under the lazy ascend, but if it past the red screen and boot up fine than you can try to turn cpu up to 710 but dont set it on boot just incase your phone starts rebooting on its own.
mine has a blue android screen![]()
think the 672 is max on that build.Ok, lol I got stuck on pg's blue android screen well it kept booting through the whole army GI Joe stuff but on bobs I got past red screen and it installed no probs. I have it oc'd to 672 but there's no option to go higher since its the lazy ascend build. I thought maybe my phone can handle 691, and that I could use setcpu to do it. Is that possible, or am I reaching here? A lot of this lag may be from a poor signal and I haven't figured out how to apply DTs apps2sd feature.Do I need to partition my card for that? I read that its within this cm7 build but its not working on its own because i cant move all my apps.![]()
I have a Cricket ascend running this ROM 0624. My text messages have not came through for the past four days. Can I call customer service or is there a fix here on the forum that I can't find?
