The "LAZY" term is referring to whether your particular handset can tolerate the CPU being overclocked past it's original factory clocking of 600 MHZ.
The majority of ASCENDS can tolerate O/C up to 710 MHZ,a few more,(748 MHZ).
Unfortunately,some do not tolerate overclocking very well,to varying degrees.
That is why some updates of CM7 are available w/overclocking to 672 MAX(aka the LAZY version of a particular update).
The typical overclock maximum setting for ASCEND CM7 ROMS is 710,w/a few versions available @ higher overclocking for those fortunate enough to have one of the handsets that can tolerate the highest stable overclocking of 729 to 748 MHZ,depending upon which update is flashed.
oooh okay thanks
![Smile :) :)](/styles/smilies/google/smilie.png)
Upvote
0
