PlayfulGod
Extreme Android User
I flashed over n flashed gapps again. No issues have shown their ugly heads yet.
ohh yee, i just flashed over without wipe, everything seems to work fine, any tests i shud do?
camcorder works, mms works, when i press reboot the bootloader thing isnt there so i got the latest update..
I tried running barcode scanner and qr droid... Neither work and now my camera says cannot connect to camera...
I tried on 710mhz and 690mhz.. Any ideas?
Well, I don't think Huawei would ever release Android 2.3 on the Ascend. So, I took it upon myself to try and get it on there. I'm currently releasing builds (should be beta stage, now) of CM7 (Android 2.3.4).
If you'd like to go ahead and try it out, please visit my wiki here: CM7-Ascend - Prepaid Android
Please remember that I do this in my spare time. I don't even use the Ascend anymore, so I can't say it's really a big priority for me. However, I'd like to get all the kinks worked out. If you do link this somewhere else, all I ask is you provide proper credits. Thanks for looking.
Screenshots are available on the wiki page.
isaacj87
Alright.. Thanks..They don't work. Somehow in 2.1 Huawei was able fake autofocus support. I can't get it to work in 2.3. When they fail they clog up the camera. Restart and camera will work again.
REQUEST: Please do not PM asking for personal support. There are many people who are doing this and it's not fair to others or myself. Post questions here on the thread. That way any others who are having trouble can see too. Thanks.
Edit: Doesnt work on 600mhz either
Alright.. Thanks..
Another problem..
My wifes phone.. I went from cm6, I did a full swipe and all.. It installed and it gave me an option for a set up wizard.. So I tapped set up wizard.. Now all it does in a boot loop... I installed it again and it does the same thing..
I dont remember it giving me an option for set up wizard on my phone.. Both using the latest cm7..
Using CMW 2.1.5.8 I think thats the number..
Well seems IM having more and more problems with this current version.. Now when I enable mass storage, it locks up on the screen, then goes into a boot loop, then back to the home screen...
the new version is amazing, soo excited that everything works. definately a big upgrade from cm6 and the toe2.2 has nothing on it. great job. got the wifi thing worked out and have finally been happy with my phone
Go to Voice Dialer and say "Open APNS". Then check that the Metro PCS APN has the green dot. ^.^I can send mms, but cant receive..I did the Metroff update also..
It isnt working on my wifes phone running cm7 either..
I think he got it working. He just had to make sure that dot was green. ^.^which metro off did you flash, if you running on new build cm7 flash this on by PlayfulGod, and a thanks goes to him also... MetrOFF.v1.2-MMS-[GB]-No-Roaming-Off.zip
