First off, thanks for the great ROM.. I seem to be having some screwy issues regarding the sd card and copying files via Win7x64.. Copying from Windows works when it wants to.. Sometimes after a reboot the files will show through file manager. Odd part is USUALLY whatever I copy will show on Windows once its mounted.. This is where it gets really weird.. I pushed a video onto the sdcard, plays fine.. USB mounted in windows, moved the file to a different directory, unmounted.. The ascend is still showing it in the old directory, AND it still plays.. Mount in windows, it shows the new directory, AND still plays..
What I've done..
1st Flash.. CWM 2.5.1.8 (I think.. the one i used for icarus and cm6)
Repartition 256ext 32 swap, reformat sd card after install..
flash metroff.. started getting the errors shortly after..
2nd Flash.. Diff SD card.. Upgraded to 3.0.2.8.. Same partition, installed, format, reboot, flash metroff.. same issues after a few mounts..
I've reinstalled the drivers, fixed permissions, multiple reformats (both through cwm and windows (fat32 4096 cyl), bashed my head lol.. Is this something that anyone else experiencing or am I just the lucky one
If anyone could point me in the right direction I'd GREATLY appreciate it..
Even though this isnt a dealbreaker for CM7 which is awesome btw, just irking me that i cant figure it out..
Thanks in advance..
EDIT: and after that long winded reply i just noticed the post above me said new build tonight.. maybe that'll fix it too
