Ah crap, now Lookout will not open, should I uninstall and install again
Thank you again, everyone on here has been very helpful, I appreciate everything.
New build is coming today. 0512 is already available on ROM Manager.
05132011 will be available on ROM Manager and Wiki later today. I've removed OC'ing up to 748. It's now back to 710 for all users. This should clear up problems with users not being able to run builds 0509 or later.
Two issues I'm running into:
1. SD card seems to unmount itself occasionally. Went to take a pic and said SD card not found.
2. Can't download Google Music from the Market. Says it's not compatible with this device.
Cricket Huawei Ascend M860
Used CWM 3.0.2.8 and CM7 05042011
I am currently running Icarus, but would love to try CM7, I am using CWM 2.x.x. I guess i would need to install CWM 3.0.0.5 before I can install CM7. Now, if, for ever reason, I need to or want to go back to Icarus, can I use CWM 3.0.0.5 to flash back? I know I can't use a backup from 2.x.x, so this would be a fresh flash, if possible.
Thanks,
Awww, I was looking forward to OC'ing higher than 710. Oh well. As long as it works. Thanks for the help Isaac.
im on 0513 and im oc to 729mhz...
Nah, you're not. I haven't release 0513. Unless you rebuilt with the OC kernel back in there.
Thanks man. I appreciate the support.
Also, I have some really awesome news. CM7-Ascend is now in ROM Manager! You can simply go into ROM Manager, grab the latest build, latest gapps and simply flash. Also, if new builds come, you can simply grab those as well and stay up-to-date!
Also, I'll upload MetrOFF to ROM Manager so that you can simply flash it from ROM Manager as well! Pretty freaking sweet if you ask me.
I've stopped building CWM versions and I no longer support CWM 3.0.2.8. I'm asking all users to use the official CWM 3.0.0.5 found in ROM Manager. This isn't a big deal as ROM Manager will force you to install CWM 3.0.0.5 before you can do anything else within it.
A new build 05122011 is already available with a [confirmed] USB mounting fix.
Happy Ascending.
if u have rom manager premium check in it. 0512 is available thru it.Is the latest build: 05122011 available for download yet? The download link is for: Build (05092011): CM7-Ascend-05092011-signed.zip
