nuttmeg
Extreme Android User
Yea man, What you said. This forum ROCKS!!!!!!!!!Metro can kiss my azz, Cmon.
hahahaha, yep yep bump metro...btw did you get mail i sent?
Yea man Thanks.hahahaha, yep yep bump metro...btw did you get mail i sent?
Main Page - Prepaid Androidwhat is the wiki because when i tried to download through rom manager it said i had an error.
Im about to brave this new build on my own through ROM manager. I already flashed Clockwork Mod recovery and did a backup. Now I went to Install Rom from sd (Which I already got from Wiki - 0514). So my question is do I wipe Data and Cache or just go with Wipe Dalvic Cache and do I also have to do Gapps? Im in training on this but Im excited about getting the new build. Thanks in advance for the help.
You da man issacj87 - YOU ARE THE MAN. Im good to go. Thanks to you and all involved. I certainly hope you get your pony.When that little popup comes up, just wipe the dalvik cache. I've been doing that over 10 times now with no problems whatsoever. I'm glad you're taking advantage of ROM Manager. It makes my life a little easier.
u said that 710 was the new max plus too much work getting all my apps back when i feel bored i will do it plus 729 been rebooting alot now im goin to switch neet week if there isnt a new build up by then..And you can't have 729 MHz on build 05142011, why? lol
Do I have the lazy Assend? cm7 0509 oc'd to 710
On first boot, everything is a little sluggish.. Most icons are the little green android for a few seconds..But after everything clears up, it runs real smooth..
Angry Birds is still sluggish after a few minutes of play, just as it was with cm6 and icarus..
I s overclocking the only difference between 0509 and 0514, I have 0509 and loving it, my ascend is working fine at 729,should i upgrade to 0514???????????????????????
Im updated to the current rom and did the 748 update and everything is running smooth..other than the bluetooth..
How do I get the google search bar to appear on the main page. I had it in the last update but it appears to be gone in the 0514 update?
