ElasticNinja
Android Expert
Did you get officially added to CM? Thought I saw it in Nightly changelog
irc.freenode.net
#ascend-testing
No, that was TomG. He got the Huawe Pulse officially added. I hope to get the Ascend added soon.
Thats good to hear
TomG is great
He got CM7 kicked off for the Blade and along with HCDR Jacob got it officially added
Wish you the best of luck Isaac
Thanks! I really appreciate it. Yeah, I wouldn't have CM7 on the M860 without TomG and Jacbo is quite the tech whiz too.
We're all still in there if you want to come join us in IRC. :]Is the testing complete Issac?
On stock and Icarus the autorun.iso has the usb n various other drivers needed. On CM6/7 the iso image has nothing but a dummy image and neither is setup to run the iso as a cd like stock/icarus is. I messed around with this last week to try and get it to work with no luck, something isnt coded for it to work. Also the original iso is over 11MB which is a big hit to internal RAM/storage.
You also have to keep in mind CM isnt developed for the Ascend but higher end phones. We are just fortunate enough isaac ported CM6/7 over for us to use. SO we all need to keep that in mind when complaining about stuff that doesnt work and show some appreciation for all that does work on both. Same goes for pip for maintaining CM6 and continue improving it as isaac works on CM7 now.
Ok so I follow everything typed in the guide to install cm7 but once I reboot my ascend it stays on the Boot Screen ive been trying for the last couple of days to get it working im using the CWMod from icarus but still nothing can anyone give me some help idk if anyone has had this happen but I havent found anyone saying they have... Anyone have ideas?
common problems for some users and isaac is working on a new build to help rid of the problems, btw what build did you flash?
Edit: Sorry I'm not Isaac. LOL
I flashed the lastest two 5/14/2011 and 5/09/2011 ive been thinking that maybe the roms were damaged I'm going to download the latest one once more but I cant update ClockworkMOD to 3xxx im using 2xxx but I guess it doesnt matter
yes may have got corupted some how moving from the pc to sdcard, make sure to look at the size and compare them...
At first I used my usb to from my computer to my phone now im using a card reader and adding them straight to my sdcard
nice...works better that way cause with older build the transfer wouldnt transfer right...
New build is up. 05212011. Check changelog.
all good!!!
