Hi everyone,
I'm new here but have found that your guides and instructions are very very clear and easy to follow. Has anyone had problem with the Ascend getting stuck on the red/black/green boot screen after flashing 5/21 ?? I had flashed 5/14 and it worked fine. No matter what I do, I can not get this version to flash propperly. Any help would be appreciated! (my other option is to us 5/14) :|
Before i switched to cm7 frum cm6 i formatted my micro sd card for my huawei ascend then went on to install cm7 everything works great but when i tap the stock music player icon it shows no music files wat so ever!?I have alot of music on my sd card so i know its there and i cant switch my ringtones to mp3's because of this problem do i have to reformat my sd card?
I'm currently running 0509 and have been since it came out but, just recently meaning today, I can not transfer files to the SD via USB. I know that this has been an issue and was recently fixed but my question is, since this just started happening, could this be a sign of my SD card going bad? or Could this just possibly be the USB mounting issue finally showing itself? I know its kinda hard to determine whether either one is correct but has anyone else had this issue after running the ROM's for nearly a month?
Alright.. I've never had problems with the previous builds AT ALL, but TWICE already on this build my phone has unexpectedly restarted after working fine for hours and will not move away from the red ascend m860 startup screen. I have no choice but to reinstall CM7 again! Any idea why this could be happening??
Yes I did do that both times.
I formatted threw the computer i think i made a mistake doing that?
I should be at the default settings CM7 had
that build had mounting issues, and the 0514 had been fix for that issue, and0521 is stable, with everything working.
guess it was just an issue with 0509 like you said that just hadn't shown itself until today, updated and everything is running smoother than ever, now to restore all my non market apps![]()
not saying you didnt, but once re read you sometimes notice something that you skip, but not to worry with all the support on here you cant brick this lil engine that could ascend....
only thing i can come up with then is placing the two files freshly back onto the SD and retrying the installation again, if all else fails then maybe you try redownloading the files and repeating this process
frustrating I know but if done correctly everything should function properly as i just flashed 30 mins ago 0521 and have had no problems so far
just flashed it and wiped everything as called for and installed the 0521 then gapps so far so good...did you make sure you wiped everything your supposed to and reinstalled gapps?
no go ! rrrrrr I may have to revert to CM6 is it stable? :\
stuck at the boot screen.. and once it arrived to the loading CM6 screen with the scrolling green bar... but now won't load past the black/red huawei screenPull battery and pull sd card out and see if it boots. If it does, then there's something wrong with your card. If it don't boot, then re-flash.I did format from CWM. Transfered the SD to my laptop and put everything back onto it (zips) Heck... I can't get CM6 to load either!stuck at the boot screen.. and once it arrived to the loading CM6 screen with the scrolling green bar... but now won't load past the black/red huawei screen
You will see "Partition SD Card"...that's how you format itNot to sound like a dick but i have the latest cwm how do you format the sd card threw that?
Try a reboot...fixed it for meAfter flashing the 05/21 my wifi cuts off then on again when utilized, no matter how close i am to the modem, is anyone else having this problem, what can i do?
thanks
