nuttmeg
Extreme Android User
Yes - After just using the stock launcher, I can tell performance is much better than Launcher pro and Go launcher. Both launchers are great, but don't seem to run as smoothly. I'd rather have smooth usage than customization.
with launcher pro, you have to go to preference and set your setting, and tweak it, and also disabling wallpaper scrolling speeds up you home scrolling also...
no offense isaac just don't see any point in fixing it if its not broken
attempting to uninstall and reinstall it to see if this fixes the issue. If not, then here comes hours of customizing again -_- *shakes head*
