septembersrain
句_句 Smurfing Awesome
I believe that if any of the screens were removable, Isaac would of attempted to remove them. Though that red screen is his, I definitely think that should stay.Very happy with the latest build.
MY lagging after running common apps has ceased.
The sdcard is now readable as a Removable Disk on the one XP PRO (SP2) box I had problems with.
It's scary snappy running @710MHz, although I did have a single forced reboot at that speed.
Camera and Camcorder work very nicely now.
However, Barcode Scanner still won't run and it still kills the camera until a reboot.
While not a big deal, it would be nice to understand why this is.
I have two questions.
1. Flashed MetrOFF but could not send a picture.
While sending I received a Make more space on the phone message. Ideas or setting suggestions?
2. Are the splash screens prior to bootanimation needed, if not, can they be removed and how?
Thank you
As for the barcode scanner, The only reason why it worked at all on stock was because they pretty much had the rom "Trick" the phone into thinking it had auto focus. When In reality, It doesn't. I'd think in order to get this working you'd likely have to break something else. X_X
Also, If you are trying to send a .PNG you'll have problems. For some reason it always gives me issues sending or receiving them. If not, Perhaps try MetrOFF again? I used it and I've send and received fine. :]
I got one "Make more space" message once. Though it happened while I was downloading an app..I had more than ample space. I guess that is just a little quirk?
What is the consensus on Launchers for my ascend? lp, adw, go launcher? something else?
We all get that unless the sdcard is partitioned.
