thanks for ur help bro. : ) ohh. one more quick question. how long will it take? (i saw some dude say somewhere a few hours but idk he was talking about cm7)yeah, flashing a new rom will format the old one and just add the new one, in your case our wonderful cm7 :]
All you need is rom manager :]
nice. thanks again dude. : )took me all of ten minutes to flash a new rom.
takes me 3 minutes!!!![]()
Makes sense. Also, How long/how did it take you to learn the codes and stuff for the phone I was looking at your github and just wow, I kinda got stumped. It basically reminded me of like command prompt. Doesnt seem SO hard to learn, but it would be a work in progress, I have to give you props.
I think he cheated! he has a time machine! ten minutes is now 3!
the oc settings are more acurate now than before, so if your phone handled 748 b4 it may not now, like mine, I had to clock it down to 729.i guess the oc748 done not functuion anymore with the 514 build? the build works fine until i install the zip and thne the phone only goes to the ascend boot screen and goes no further. i was just curious how the phone handled the 748 oh well no biggie.
all I can figure is your phone doesnt like the kernel.im just curious why i can get the 0514 build to load up after flashing the 748 oc zip. i know it was designed for that build so i thought it would work. the 0509 will not load at all, i used the currect gaaps and flash metro off1.3 and all it goes to is the 2nd huawei screen no matter how many times i try to redue it. any ideas?
What build of CM7 are you on? As far as i know, the camera should work. I am running CM7 05072011 and everything works great. (i know there are newer builds...just like the way my phone is operating) I have heard that certain apps for the camera will force close it. I think...if it freezes up or stops, just lock the phone and unlock it again. I saw somewhere that it should work. Hope this helps.So, i just flashed yesterday to CM7 and I love it so far. However, my camera does not work at all. I get a force close or report option whenever I use FxCamera. Ive researched some stuff, but they're not exactly clear. Can someone help with this problem please?
I gotta have my cam.
