K
KOLIO
Guest
Anyone still having MMS problems should try APN MANAGER by 81 square,from the ANDROID MARKET.Very simple fix for my CM7 CRICKET MMS issues.
Got a quick question.
I was just looking at the wiki page for CM7 and I saw this:
New custom Gapps package. This one includes Google Maps 5.3.1, which runs great on the Ascend. (Temporarily down, 20110307 is back up for now.)
Is there supposed to be or going to be an update for the gapps? Or is it basically the same thing?
You need to post this in the t-mobile g2x forum. I'm sure somebody there will be able to help. Good luck.Is there any ways to play videos on TV from a g2x with the RCA cables(instead of the micro HDMI?? I'm I supposed to change any settings?
Are there any known bugs/features that don't work or work well with the newest CM7 for Cricket? I want to flash to a mod that is the fastest possible, but don't want any errors or bugs that will frustrate me (had enough of that with stock!) ALSO: will PDAnet work with CM7??
I suggest backing up your current ROM & try out all the ROMS.If stability is your utmost priority w/100% functionality,go w/ICARUS 1.1
From what I've read,CM6 is 100% functional as well,consult the CM6 thread for more info & feedback from CM6 users.
I'm currently running CM7 05212011 & used the app APN MANAGER by 81 square(in the market)to solve my only issue,(MMS).Everything else works!
class 10 sdcard and also my ascend didnt fall in the category LAZY ASCEND, lol![]()
Lol lucky you bro mines lazy as a sloth, i've tried so many ways to install CM7 but nothing hmmm im trying to find out info on how to fix a LAZY ASCEND but not much help i dont want to start looking for other sources on roms because i trust isaacj87 and he has done amazing work so i really want to get CM7 on mine and if i cant than I'll stick with Icarus no way in heck will i ever be going back to stock, which reminds me i did go back to stock to see if that would help but still it didn't i even tried CM6 but no luck i honestly wont stop until i fix this phone lol although im also thinking about selling it to my uncle since he likes it so much and just get another ascend since their like $50 (w/ a new line) and just give my girl my old Samsung Messenger and hope i don't get a lazy ascend lol
my cuz had a lazy ascend also, had flash it twice today and on third install it finally booted, but when i wipe data factory rest and cache, i also formated it again under formats, than i went to advance and rebooted recovery and did it once more of wiping and formating, than started installing cm7,gapps,metro off and it work...
So i should:
Wipe Date/Factory reset
Wipe Catch
Wipe Dalvik Catch
and go into Mounts and Storage and Format:
Boot
Data
System
Catch
Then go into Advance - Reboot Recovery and do it all once more correct?
Did you Flash CM7, Gapps, and MetrOFF at the same time?[/QUOTE
yes, that is correct!!!
Sweet ok im going to try a couple more times. You used CWM 3.0.0.5 right?
hmm so ive never rooted a phone and i dont know how. but i would really like to and am a lil confused. can anyone help me?
thank youwhat benefits exactly does this give me? i saw it speeds up your phone and such which would really help. but mainly i want to do this because a friend told me it would unlock more features to my phone and said its possible to use an app and emmit wifi from my phone so i can play my ps3 on it. is their a link to a guide of how to use the features and what not to do?
I have a two part question:
If you upgrade to the official 2.2 on Metro, can you flash cm7 afterward?
If so, will it be any better performance-wise? Just a thought.
ahh ok so i saw ppl were talkin about backin up your phone...does the free version of titu do that? or do i need to save it to my computer somehow? also how do i download icarus is it in the guide u gave me? sorry for all the Qs im completely walkin into this blind just want to make sure i dont mess up or somethin
