BILL88STANG
ok since i got frustrated with the no a2sd on the official metro update i decided to go back to cm7, but it go stuck on restoring cache, im trying it a second time. has anyone run into this yet?
Is there a way to reset the APN for cricket? all of a sudden I can't receive MMS and I am not re flashing again,I've done it once since I couldn't receive MMS, it just says unsuccessful, i can send them however
I just selected the appropriate carrier,(CRICKET or METRO PCS),mine being CRICKET,activated APN & left the rest of the settings alone.So far,SMS/MMS works,was able to attach an article & successfully sent & received the MMS to a NON-CRICKET phone.Currently testing w/a CRICKET to CRICKET MMS. Will post results as soon as possible.
UPDATE:Successfully sent & received an MMS containing a video attachment from one CRICKET phone to another. 100% SMS/MMS Success!
Tried that already, still cant download mmsDownload APN MANAGER by 81 square in the ANDROID MARKET.Select CRICKET as your provider,activate & leave the rest of the settings alone & you should be good to go.
How do I change the function of the call end button to take me to home screen? It puts phone to sleep.
Thank you sir for getting my point and not just my drunken rantings lmao
Anyone still having MMS problems should try APN MANAGER by 81 square,from the ANDROID MARKET.Very simple fix for my CM7 CRICKET MMS issues.
Go into your apps and run Spare Parts. Look for end button behavior.
finally someone wit the same problemThat didnt work at all for me
Im on cricket... But it seems more n more ppl are havin probs...I wonder if its because of the merge with pocket?! Cuz I know they are trying to get rid of pocket service altogether while trying to "merge" their towers :/ smh @ crickets nonsense
