quick question. Does the below do all the wiping of cache/dalvik/data that you need to do before flashing rom? Meaning i can just flash this and be down instead of having to boot into recovery and wipe things manually? Is there a step by step on how to use the tool below?
Calkulin's Format All - Flash prior to flashing ROM. It will wipe everything for you including /system, which normal data wipes skip (they only wipe /data and /cache)
Direct Download:
Calkulin\'s_FORMAT_ALL.zip
Calkulin's Clear Temp - Clears temp files from cache, data & SD card partitions (Good to do before backup)
Direct Download:
Calkulin\'s_ClearTemp.zip
Between those two files you should be good to go.
Keep the suggestions coming guys!!
The file isn't unzipped unless you unzipped it. It'll be right where you left it likely in your downloads folder for flashing again and again. I flash it before flashing any roms and flash clear temp before backups. I'm anal though so I still wipe everything manually too.
Hmmm I dunno bud I don't use astro. If you long press does it give you an extract option? If so it's still zipped. If it won't let you open a file that's inside of it it's still zipped. Flashing it doesn't unzip it so it should be zipped still but you should be able to tell if it gives you an extract option our won't open a file.
Thank you!Stevcha thanks for all your help. its is because of people like you always wanting to help noobs like me are learning and helping others.
I would like to say for those with a EVO hardware 003 that I am using Kings unleashed GB R2 with savaged zen 1.3 CFS and my battery life is 14-18 hours and the phone is very stable, tempreture is under control and everything works.
Don't mention it. I remember when I was new to flashing and all the members here were quick to help me. Just trying to give back to the forum.
New to the forums...and flashing.
Speaking of Calkulin's Format All, I tried installing it and it didn't work. I saved it to my SD card and rebooted into recovery mod and tried installing the zip file. It started to install but after a few seconds it said installaition was aborted. What am i doing wrong?
Thanks in advance!
Thanks in advance!
Anyone know where I can link the stock htc kernels?
I see alot of recommendations to use Rom Manager to flash ROMS but what about the wipe you would normally do?
Just my opinion, but I would not use Rom Manager. I would learn to do everything in recovery. It is more likely to complete without any issues and if you ever have a problem and can't boot your phone normally, you are more comfortable doing the steps to fix it manually. If you are using Rom Manager, you are likely using Clockwork Mod which is know for being buggy also(Rom Manager is the front end of CWM). I would suggest switching to Amon RA 2.3 as it seems to have fewer issues with wiping(escpecially) and flashing.
thanks! would I just flash RA 2.3 just like I would a ROM? Wipe everything or exclude data?
Here is a link to the files and instructions for doing it. One thing to remember though is that CWM nandroids can not be restored in Amon RA so you will need to make a fresh nandroid after you flash Amon.
http://androidforums.com/evo-4g-all-things-root/259446-clockwork-amon-ra-pc36img-files.html
One more question. I think I need to update radio. I've read somewhere that if this isnt done right you can brick your phone. Last time I updated I just flashed it like anything else. No problem. Do I need to do anything special?
