Root root cricket zte grand x max
I installed the lollipop pre rooted ROM everything appears fine. My question is how do I update busybox? I want to update the app and the binaries. Any help would be appreciated.
Try to do the read and write command to get read and write access or try to flash the zips the masterchif has provided. Once you have read and write access I think you are able to update busy box
Let me know if it works this I'd what work for me
Thanks again for your help! So I installed xposed worked first try. I just have a few questions. Do I need to make another nandroid? Do I need to backup again in titanium backup? Also which modules do you recommend? I use the r/w script install twerp again without opening it and then install modules correct?
After you have r/w, install modules you want and Hot boot. This way you're modules will install and you will retain r/w. I use Hot reboot script in ROM toolbox
Hi does anyone know if I can use this phone with a 32 gig partitioned SD card?
I want to move all my large data from games and stuff to a second partition with link 2sd but I heard some phones don't support the second partition.
Just open ROM toolbox, go to scripter and run hot reboot script. There's a bunch of pre written scripts there
I did it worked great. I was reading through this forum and saw all the setbacks and stuff you guys had in the beginning. phones bricked etc. I just wanna thank you guys for still being here to help new people like me so we don't have to go through that thanks.
I currently have a 32 gig SD in mine. For some reason, I cannot through phone move anything to SD card using Root Explorer. However I can move anything to SD when I plug into my desktop. I do this to move large files like movies. I am able to move apps to SD through system settings though. Hope this helps, but remember I am only root through Kingroot and script on stock rom. I do not know how MasterChiefs zips work with this, hopefully he will comment or just ask him.
Hi right now I'm using a 128gb micro SD card on the phone works great hadnt had any problem. I just had a problem the first time I put it in it wouldn't recognize it. I had to take it out and put it in another phone then back to this one and it works no problem since them and how big of a file you are talking about I been moving things from the phone storage to the SD card like videos with no problem. But it could be that my files are smaller then Christopherco is trying to move. If you can tell I can't try to create a file that big and try to move it. Oh and by the way I'm using lollipop with masterchief87 zip.
That's fantastic, I always thought I could put a bigger SD in this phone beyond it's rating, now you confirmed it. I am out to get one in morning. I am literally making this phone my personal portable hand held computer, and the more memory, the better!! Thanks
I hope it works I'm using a Samsung brand I think it says evo
I couldnt wait for a reply lol I had a extra card so i took a chance. I used aparted to partition and I'm using es file explorer to move files. Everything works fine,no problem with large files. I'm using link2sd and foldermount to move my large game files. I might go the 128 gb route! Thanks guys
