Codegerm
Android Expert
Yea. That would be the one. Is there another way i could get it?
Read the link I posted. It will tell you how to get it.
How do I un root back to factory stock? brother in-law rooted my phone while borrowing it!! now the boost phone shows sprint everything!! I just want it back to stock! can someone please tell me how!??!
Edit: I can confirm that this process also works for FI22 and FL24. It should also work for any TW build, though you may want to grab the corresponding kernel here (i.e., if you're running a JB stock rom, make sure you get a JB kernel). I would also mention that, if you have 4g service, most custom kernels will bork your 4g speeds. You're only going to get 4g speeds with stock kernels or AGATs repacks (which are on the linked page). The repacks are just stock kernels with custom recovery that will leave your 4g speeds alone. So if you want fast 4g speeds, get a repacked kernel. If you don't have 4g or don't care about speed on it, you can get any compatible kernel you want.
But, as noted above, if something screws up or isn't working right, just flash back to stock and try again.
Any of the jelly bean tw roms work flawlessly. Just pick one
Is anyone else willing to test the root tutorial using the stock GC01? I tried it last night and it didn't work (the device wouldn't ever boot).
Makes sense, any alternatives out yet that may work?
Yeah every thing works. But your going to need to do the mms fix on any sprint rom u flash.
A gps lock is exactly what it sounds like. When maps can see u to 30 meters or less u have a gps lock. There are apps thats can help u get a gps lock faster. And let u kno when u have a lock
agat63's looking for testers for the Boost GC01 repack: http://forum.xda-developers.com/showpost.php?p=39727156&postcount=32
