i.have.droid
yes downloaded and installed HTC driversdid you download the drivers?
I just started the processHow far along are you?
If you already have s-off, then you can use the usb mode to get the files you need on there... (the su file for example)
Thanks for the vote of confidence, just afraid of bricking my phone, do you suggest unrevoked, revolutionary or ????Please take your time are read a little. You should learn how to do this on your own. With root comes a lot of responsibility with your phone, the more you know the better off you will be.
Try to follow the guide step by step, and if you get stuck, let us know where you are and we'll get you through.![]()
read the op ocn made a whole guide on how to root your phoneThanks for the vote of confidence, just afraid of bricking my phone, do you suggest unrevoked, revolutionary or ????
can you use a wired tether app and run revolutionary?
someone posted the file for Clockwork mod and Amon Ra PC36IMG. put it on the root of your phone and when you go into hboot it should ask if you want to install an update.Okay that was a great idea, but here's what happens. When using wireless tether the usb drive is busy so rev cant read my device. So i let it read my device, when the download recover question comes up I eneable usb tether and download. Then it says done... Rebooting to fastboot. And again it cant find the device since the drive is busy. So i tried unabling usb tether again. I tried pretty much everything after that and it didn't work. So the usb tether method wont work. Good idea though. I even tried re running rev after it downloaded but every time you run it it has to download clockwork again.
hmm that happened to me and i just had to reinstall drivers =/ are you suign the ubs cord the phone came with?
1 recognizes it but when i click it says"please insert disk into removable disk drive". The other (win7). does not recognize it and I resintalled the HTC drivers..
ugggghhhhh
Haven't done anything yet, just been reading and trying to figure everything out.So whats the problem? What files are you trying to copy over? Do you have S-Off?
Do you have S-Off? If so, you could try whatever root method you used again (probably revolutionary) or just put the recovery PC36IMG.zip file in the root of your card.
It's good to be sure of what you're doing (before I rooted, I read the dummy guide +10 times and watched a video of someone rooting several times.Haven't done anything yet, just been reading and trying to figure everything out.
Okay, I'm gonna re-read over Ocn's post and get back with you. I think you just have to do the file whenever. I mean, you need a custom recovery to flash the Superuser.zip file anyway....
Okay, so before you start you should put the Superuser file on your SD card (root), but you have custom recovery in the actual root method process... so you should be able to do it after you get the custom recovery by following the Revolutionary process.
Hope that helps.
I don't know how to put the file on the root. I use astro but i cant mess with the system cause im not rooted. I also dont know how to get into hboot or back into recovery or any of yhat.
Whenever I try to get in hboot I've done both:
Holding power then volume forever.
And pressing and holding them simultaneously forever. Nothing happens untill i release then it just turns on. I can't get in hboot.
Help! I'm stuck!
So Im trying to flash the superuser zip file and everytime I select it, I get an error as follows"
E:signature verification failed
Installation aborted.
Then it takes me back to:
reboot system now
apply update from sd card
wipe data/factory reset
wipe cache partition
What am I doing wrong?
Also, when do I install amon ra 2.3? I'm confused???
