Keep getting invalid beta key...entering it exactly as it appears when given...any ideas?
Did you turn Fastboot off?
Did my first evo..Worked great. Now when i right click on Rev file to run as admistrator, the cmd windows closes. Why?
Question on system updates now that I'm rooted. I know not to do the HTC software updates. I assume PRL updates are OK. What about firmware updates and profile updates?
ok lets try this backup your sd card on your computer. on your phone reformat it. it will erase everything. next lets do a factory reset on your phone. then lets try revolutionary again.
firmware no, profile yes. never do a software update now that you are rooted. it could change your hboot and then you will be unrooted and with no way to re-root. the devs will come out the ota cooked into their roms at some point.
I have the same problem as HAMBO, getting the message about saving Caroline from doom and not writing at block 0x0000000.... I formatted the SD card and did a factory reset and I am still getting the error. Any other ideas?
welcome to the forums!!!!!!!!!!!!!!!!!
9to5 brings up a good point. it could be your card. what size card do you have?
Thanks for the welcome! I have an 8GB card. How would I be able to tell if the card is the issue?
Hi people,
for some reason windows doesn't recognize my device; installed latest HTC sync but in vain. Tried on different PCs, same problem!
I think i should change the usb cable, but for the time being is there any way that i can root the phone without using a computer?
i have a micro SD adapter, so can transfer any files from PC to the phone.
Thanks in advance..![]()
I just rooted my evo!!
Thanks to this great guide.
Before I rooted I did download the new 4.53.651.1 update.
and it worked.
Sorry I posted in the wrong thread.
It was suppose to be in the gingerbread Edition.
moved you to the right thread.
thanx and congrats!!!!!!!!!!!!!!!
that is good to know that the latest ota did not close the exploit that revolutionary uses.
Sorry...this is my first root and don't want to screw anything up!
I skipped the step of adding the su file to the card...I have s-off, can I just add the file to the card and flash as normal?
Thanks!
try not to do multiple postings. i posted an answer to your other post.
Thanks and sorry
Awsome I was really nervous about doing this but I'M ROOTED NOW!!!!!!!!!! can't wait to see what I can do now!!!!!!
Thanks,
Charles
