have you tried running revolutionary as admin?
Yeah tried running it as admin n still nothing
Do you have another pc you can try and use? I have seen it before that something on your pc(not sure what) can cause issues but switching to another pc solves it.
I've rooted my previous EVO just fine on the same computer. I'll try on another computer n see if it'll work. thanks for the tips
most of the stuff on your card is not needed. you can leave it empty and everything will work. most of your apps and stuff will have data backed up on the card. so it will be up to you what you put back on the card.
do you have the old drivers used for unrevoked on your computer still? you might want to unistall those. not sure if that is the issue, but i would try that. and just to be sure you installed the htc drivers from the revolutionary wiki right?
So I finally got revolutionary to read my phone n was able to enter my key n everything only kuz I had to restore my comp to factory (which I really didn't wanna do lol) well I got this error saying something like sending to Caroline or along those lines. Now my phone keeps turning on n off on its own every minute n it doesn't even read my SD card. Any ideas? Please help, I can't even use my phone
Try pulling the battery then boot to hboot. Do you have s-off in the top left corner? If so, select recovery and see if you have recovery.
no, it's still s-on. do u know why my sd card is not detected? because during the process of using revolutionary, the error also mentioned domething about "error while partitioning sd card" or something
I would try and run revolutionary again. Until you get s-off, you can't do much to fix it.
how do i go about doing that?
if you have a card reader you can try and format it using your pc.
Formatted it using my comp n still doesnt show up on the phone but when I plug my phone via usb to my comp about my comp needs to install "qualcomm CDMA technologies MSM driver"
can this root process be utilized on a EVO 4G Shift, that has GB? My son is begging me to root his phone.
Thanks
Rick.
try installing the htc sync drivers if they are not already. i have never seen that before. maybe also try and see if you have anther card available to use. just make sure that it is not a 2g card. they never work well with the evo.
Install HTC sync on my comp? I also tried another 8gb n when I got to settings to check, j its not mounted n the worse part is my phone doesn't charge anymore n it turning on n off every minute is frustrating kuz I can't even use it for calls or anything
man, i'm so sorry that you are having such a tough time with this.
so to get a better picture of what is going on. you still have s-on, correct? and you can't boot up your phone?
the only other thing i can think of is to try a hard reset in hboot. go to hboot and hit clear storage. and if that does not work then you might want to take your phone in, since you have s-on.
i do not know what else to tell you at this point in time.
for some reason revolutionary.exe is not reading my phone
I installed it again and it worked but i cant find the superuser file on my sd card. it bothers me that im so close but so far. help me!
^^^ or on my apps list on my phone. what did i do wrong?
Ok, I got a brand spanking new 16gb class 10, yep, micro SDcard. I partitioned it and transferred all of my stuff over and it works like a charm, I guess. How do I go about using the a2sd function?
Thanks in advance.
