Waiting for device .....
Its on charge only which the video I found said to do.
ok do you have fastboot checked or unchecked in your phone?
Its checked. I've unchecked it and rechecked it too.
Can someone please help me, I at the screen where that says Revolutionary CWM v4.0.1.4 when I select install zip from Sdcard it take me to a screen the says REVOLUTIONARY what do I do next?
is that on the phone? what step are you?
I don't know if I skipped a step on not I was trying to find the file on my sdcard. the options that I have are reboot System no, apply update from sdcard, wipe data/factory rest, wipe cache partition, install zip from sdcard, backups and restore, mounts and storge, advanced, and power off.
Have you tried to completely delete all HTC drivers and HTC programs from your pc, then reinstall and delete HTC sync?
I'm just getting in on the action. It seems Ocn may need a hand.![]()
Yes 3 times. Ocn I tried debug off and nothing!
when i select the Revolutionary comes up
revolutionaryok do you have the su file on your card? So when you select installl .zip from sdcard do you see the file?
ok lets try something easy reboot your computer and also your phone and start all over again. make sure that there is no issues with drivers when you connect your phone. if your computer is not communicating with your phone then we need to fix that first.
Did that too. My HTC says it fails when I first plug in my phone to the laptop. Everything else is fine.
weird try running revolutionary again.
OK, super noob here. First, I apologize for these question in advance. So, I have my EVO rooted (I think). Now what? How do you get to use the phone as a modem/hotspot. How do you delete crap programs (NASCAR, Amazon MP3 downloader, etc...), how do you install a new ROM, and why would you? Thanks in advance.
so which of the options should I select?
that could be the issue. can you access your card on your computer?
