First off, thanks for the awesome guide. My EVO 4G was rooted in no time. I managed to do so with a broken Volume Up button as well! (I broke it replacing my digitizer...it's not the replaceable black rocker but the little grey thing that the rocker pushes.)
Anyways, onto my question...I'm on stock ROM and kernel, 2.3.3. I want to switch to CM7. Your guide said that in order to use superwipe, I would need to switch to Amon Ra or trwp (I have Clockworkmod 4.0). But I saw that you need a Volume Up button for installing Amon Ra and twrp.
1. Can I install Amon Ra / twrp through fastboot or some other way to avoid using the Volume Up button? I don't know how to do that but I'm sure I can look it up...
2. Is skipping the superwipe and sticking with CWM 4 an option while flashing CM7?
Thanks!
this is the only time i will recommend rom manager. do not use rom manager but with it you can switch recoveries to amon ra without having to go through hboot and using the vol up button. once you switched to amon ra rom manager will not work anyways.
