"download this and put this file, superuser su-2.3.6.3-efgh-signed.zip on the root(not in any folder) of your card via usb cable."
How do i do this??
1. download that file.. on your computer.
2. plug your phone in to your computer, with your USB cable.. put it in Drive mode.
3. on pc.. open file manager .. open the drive that represents your phone..(this should be the main root directory of your sdcard)
4. find the file you downloaded... drag and drop; or copy and paste.. to the main root directory on your phone sdcard, not in some folder of your sdcard.
running s-off hboot 2.16 and clockwork recoveryOk so i flashed the evervolv rom onto this phone, and everything works very well. But iv already found another rom i want. when i go into this roms settings it wont let me change the usb connection to disk drive...and when i plug it into my pc no options appear either
I used this guide to the bone and it worked very wellrunning s-off hboot 2.16 and clockwork recovery
welcome to the forums!!!!!!!!!!!!!!!!!!!!
glad you were able to get your root on. try going into recovery and select mounts and storage and select mount usb storage. this should give you the connect from pc to your card. you should be able to transfer the file that way.
and double check your hboot. rooting with revolutionary should change your hboot to 6.16.
Will do...next time. i just ended up restoring it to a couple hours back before i flashed the rom and am doing it all again. i always seem to think of something right before you guys reply sadly lol. I am coming to this forum site from now on you guys awe awesome thank you so much!
Really? I'm going to have to try this from now on. I am waiting right now for the energy rom to load. I am excited to finally be doing this. Id like to switch recoveries but will i have to re-flash the rom as well??
Hmmm, not sure. Which DInc, 1 or 2?
Get to step 6, it zergs, aquires root, sends in caroline, then just says "waiting for fastboot..." I have uninstalled and reinstalled HTC drivers, and redownloaded revolutionary, get to same step every time. I am doing this in a virtualbox running xp on a mac if that makes any difference. Am in USB debugging, and Fast Boot is unchecked.
Why has this topic been unstickied???
Hey guys, new user here and I just got my Evo rooted thanks to this guide. My problem now is that I can't find the option to make a nandroid backup. Can anyone help with this?
A BIG thank you to ocnbrze
I am a total noob. I bought an EVO 4G a week ago and rooted it and flashed 2 different ROM's since then. With this guide, the root went perfectly and flashing the ROM's was easy.
I have to say, I searched and looked at every EVO root thread and instruction google offered up but when I saw this guide and read it (several times), I knew I could do it!
This was the BEST instruction I saw period!!
Well done and thanks to ocnbrze
Yet another flashaholic created by ocnbrze. I'm right here with you. We should start a Flashaholics Anonymous group.
"Hi, I'm vailpass. It's been 38 minutes since my last flash."
i just open door ways and show you guys the light
Yeah..... I want to flash some more stuff........I'm getting a kernel urge......don't really know yet what a kernel flash will even do for me????"Hi, I'm vailpass. It's been 38 minutes since my last flash."
Not even sure if I spelled kernel correctly...........
