welcome to the forums!!!!!!!!!!!!!!!Noob to rooting here- finally ready to do it- but with a little research I now realize it may not be possible as my HTC EVO 4G has Android version 2.3.5, kernel version 2.6.35.10, build number 4.67.651.3 ....the update at the beginning of this thread said the 'revolutionary' method won't work with these versions (as of course up until now I have been accepting OTA updates)- just looking for a quick answer or links to any other options that are being worked on or are even available now to get my phone rooted as it stands.. thanks in advance for any feedback
i was trying to unroot and i got the phone to go back to s-on and i put the file pc36img on the sd card but nothing happens after i reboot it in recovery mode
like rxpert says, you will need to get into the bootloader so power off the phone then press and hold power+vol down. this will take you to the bootloader screen.
make sure that you name the file correctly. it needs to be exactly PC36IMG. keep in mind that windows by default hides extensions. so do not add an extra .zip to the name. otherwise, the file will be named PC36IMG.zip.zip which will not work.
also the file needs to be on the root of the sd card which means not in any folder. place the file just on the card.
just out of curiosity why do you want to unroot?
Alright ive Done everything like you said and in the bootloader it takes a few seconds and says checking PC36IMG but it never asks to do an update
i want to unroot because I bought the phone used and it was already rooted i don't know anything about rooting so i think it will really go to waste
Hi all. Been reading and using everyone's advise for quite awhile now, but it's my turn for needing some help.
Tried unrooting my phone yesterday and I've got the same situation some of the others have in that I have s-on and a newer radio.
already flashed hboot 6.17 zip, then tried the 4.54.651...but I'm stuck here. hboot still shows 6.17.0001, s-on, radio 2.15.00.12.19.
Flashing a newer ruu fails. Images are named correctly. Being flashed in bootloader, etc.
Not sure what to do at this point. Still have su because I can go from stock to rooted roms and back. Thanks.
make sure that:Ive followed the above steps and downloaded the files for the unrooting of the HTC evo 4g, when i try to rename the RUU to the PC36IMG.zip and place it in the root and run i get
SD Checking....
Loading...[PC36DIAG.zip]
No Image!
Loading...[PC36DIAG.nbh]
No image or wrong image
Loading...[PC36IMG.zip]
S-On
Hboot-6.17.0001
Radio-2.15.00.05.02
Please help, Thanks again.
Is it to late to get back to s-off now that i have turned it on but have not made it through the final stages of stock form?
Can't re-run Revolutionary at this point. The hex-edited PC36IMG.zip file will fool Revolutionary into thinking the device is already rooted (due to the number), so that won't work.you can just re-run revolutionary if you want s-off again.
what ruu are you using?
why are you unrooting?
At this point, unrooting must continue, unfortunately. The 4.54 PC36IMG should work. If not that, then the RUU should work (it almost always works if the device is put into fastboot first).
welcome to the forums!!!!!!!!!!!!I am trying to root my Evo 4g 2.3.3 and I made it through the entire process, until you unzip the superuser.pk. I get the superuser.pk on the phone, then get into revolutionary mode, but when I try to unzip the superuser.pk it says "no data." Any help would be much appreciated.
Thanks ocnbrze!
I followed a you tube video (How to Root the HTC Evo 4G in 5 minutes! Part 2/2 (Gingerbread Edition) - YouTube) to try to root the phone, but it didn't work... which is why I am here.
Can you recommend a easy rooting option for the EVO 4g with gingerbread 2.3.3, the less steps the better.
Thanks ocnbrze!
