Matlock
I wonder how many more pages we need for this thread to be stickied![]()
This was one page 4, post #179.
So yeah. 9 Pages! Rofl
WIPE
Use the VOL DOWN toggle to move to Wipe and select by pressing the POWER button.
Toggle down to Wipe date factory reset and select by pressing the POWER button.
Once that has complete, toggle down to Wipe Dalvik-cache and select by pressing the POWER button.
Once that has complete, select Return.
- this is rootable ?
, and there was toast root, People were saying about using underclock widget you needed toast root, and there were certain things that would be permanently lost that you couldnt do with your EVO if you applied the very first FOTA update and lost ability for Toast root, I assume this is false information now today ?
Even for media (full time TV port output like DroidX got with that utility, maybe even with live view also on the phone?). Just got my 3rd EVO shipped to me. It is a 3.29.651.5 Build because I knew to Cancel and say NO to the updates on first boot- this is rootable ?
I remember 2 weeks after our EVOs came out, there was unrEVOked, and there was toast root, People were saying about using underclock widget you needed toast root, and there were certain things that would be permanently lost that you couldnt do with your EVO if you applied the very first FOTA update and lost ability for Toast root, I assume this is false information now today ?
I am running your processes in this thread to unrEVOke! so grateful! What ROMs should I look for ? I bet there could be another thread about this, but some major ones, or point me to threads about the best and most functional ones ?
(I am running several businesses from the phone when I am on the road and I try to automate everything from my EVO that I can, I remember before Froyo came out some people had toast root full flash 10.1 on a custom ROM with 2.1 was still current, stuff like that only current and up to dateEven for media (full time TV port output like DroidX got with that utility, maybe even with live view also on the phone?).
What kind of exciting stuff can we do with out roots now ?
Thanks so much!
Wouldn't you recommend wiping cache as well? Good addition by the way!! I know theres been a lot of posts recently on how to do things manually... And thanks for updating this thread! Very beneficial!
For those of us that are already rooted with Unrevoked 3.21 and want the latest updated Sprint ROM, what's the easiest way to go about this? Do we still need to wait for anything?
Software version 3.30 with hboot 2.02 is unrootable via unrevoked at this time. There is a manual method but Im not sure how easy it is. Check it out.
[ROOT][GUIDE] HBoot 2.02 S-OFF - Like a Boss Edition! - Updated 11/20/10 - xda-developers
I would personally wait for unrevoked to release a new version.
Isn't that what I have written? Hmm, may need to go back through the process and recheck it.
Thanks again Matlock. I don't really see myself using custom ROMs, as I'm really only rooting to gain wireless tether and a couple other root specific apps.That depends..
Do you still want to use Custom ROMs?
Then you need to wait for the developers to create a custom ROM with that particular update.
Do you still want ROOT, without Custom ROMs?
You'll need to unROOT your device and apply the update. Then reROOT.
Or, waiting for someone to ROOT the current update, and FLASH it.
i just got my htc evo the other day and have been trying to root it for days now and nothing is working... i tried the unrevoked method as described above but when it goes through the steps and reboots the phone and should boot up the screen where it flashes the rom (it doesnt and boots up like normal) before it even goes to do the last reboot it says "triumph successful" or something like that as if it was able to root the phone before reboot... any suggestions???
What does the program say after it boots up instead of flashing the rom? It should say something along the lines of "unrevoked was unable to obtain root, this happens". I suggest running it again. It took me 3 times to obtain root when I did it.
android version 2.2
baseband version 2.15.00.09.01
kernel version 2.6.32.15-g56b9e50 htc-kernel@and18-2 #17
build number 3.30.651.3 cl272076 release-keys
software number 3.30.651.3
browser version webkit3.1
pri version 1.77_003
prl version 60672
hardware 0004
Software version 3.30.651.3 is not compatible with Unrevoked at this time. That is why it is not working for you.
That information is in this thread numerous times. And when an update is ready, I'm sure it'll be posted here as well.yeah i was not able to find that anywhere on there site as to if it worked or not... where did you get that info so i can watch for it to be updated...
