F.A.Q.
FREQUENTLY ASKED QUESTIONS
This post will be reserved for all the Freequently Asked Questions that I have been asked, and many of the members have been asked about root.
PLEASE, if you have a question, never hesitate to ask. There are no NOOB/NEWB/DUMB questions here. If you have a question, ask in the thread. Or send a Message to me or any one of the members who are frequent posters here. We'll be happy to help you out in any way possible!
Can I only apply ROOT when installing a Custom ROM?
No. You can ROOT the device prior to installing a ROM with the UnrEVOked Method. Some ROOT methods do have a ROM you download that has ROOT already applied to the ROM.
How do I UN-ROOT my device?
See
Section 7 of the Rooting Guide.
Will I still have all of my Apps and Contacts in my phone after I ROOT?
Yes. All of you Contacts and Applications will still be installed on your Device. This ROOT Method only ROOTs your device. It will not Wipe it (Factory Reset).
If you choose to do a Factory Reset prior to ROOTing your device (which is highly recommended so you can make a clean backup of your phone), you will lose all of your Apps and any Contacts saved to the phone it's self. But not to the Contacts saved to your Google Account(s).
Will I be able to install custom ROMs with this ROOT Method?
Yes. You will be fully able to install Custom ROMs with the unrEVOked method.
Should I Downgrade to 2.1 before I ROOT?
NO. You do not need to downgrade with this ROOT Method.
I am running Android 2.1; should I upgrade to 2.2 before I ROOT?
You are not required to upgrade your device to the current 2.2 Version for this ROOT Method.
If you plan on using custom ROMs on your device, you do not need to upgrade.
If you do not plan on ever using custom ROMS, and just want to keep the Stock HTC Sense on your device, and use all of the ROOT-ONLY apps, then it is recommended to upgrade to the latest 2.2 before ROOTING.
Will this BRICK my phone?
No. I have yet to hear ANYONE use my tutorial or even unrEVOked for that matter, ever BRICK their device. You would have to not follow a single instruction and do it with a blindfold on to really do damage to your device. And I highly doubt you want to do that.
Do I need to UN-ROOT to apply the OTA Sprint/HTC Updates?
Yes. UN-ROOT your device with
Section 7 of the Guide and apply the OTA updates from Sprint/HTC. Then go through the Guide again to RE-ROOT your device. You MAY lose your Applications and Contacts doing this. Some users have and some have not.
Will I lose my 4G if I ROOT?
No. You will not lose your 4G service with this ROOT Method.
You may however, lose it when installing ROMs. Some Mods have not completely got 4G working with their Custom ROMs. This is especially so with the STOCK ASOP Roms (Actual Android Rom with no Carrier Specific or Device Manufacture changed to the ROM.)
Can I still UN-ROOT my phone if I install a custom ROM or KERNEL?
Yes. You will still be able to UN-ROOT even after installing a custom ROM or KERNEL.
When FLASHING a new ROM and KERNEL, do I need to install one before the other?
Yes. FLASH the ROM First, the KERNEL Second.
Will ROOTING Void my Warranty?
Yes. Technically.
If you ROOT your device and take it to Sprint for any reason, and the Representative notices the phone is ROOTED, they have the authority to revoke your Insurance Coverage. They also have the ability to contact HTC and have the Manufacturer Warranty removed.
I just ROOTED my phone and now I am getting a notification to Update my SPRINT Voicemail.. Should I?
Yes.
Go ahead and update it. It will not hurt anything.
Just FLASHED a ROM and now I can't download anything from the Market.
Your data may have not been wiped properly. Refer to
Section 8 and flash either the ROM once more, or flash a NAND backup of your original ROM, then try and flash ROM your wanting.
While using unrEVOked, when it says "Waiting for Device".. I have it connected, but nothing happens.
Reinstall the from
Section 2 Step 2.
In ROM Manager, when I flash Clockwork Recovery "An error occurred while flashing your recovery" pops up.
Enable WiFI and that may correct your problem.
Downloaded a ROM and now my apps won't update.
Clear the Market Cache.
Setting > Applications > Manage Applications > Market > Clear Cache
After I used unrEVOked to ROOT my device, my Security is still listed as S-ON. How do I get to to say S-OFF so I can FLASH ROMs?
Refer to
Section 4: unrEVOked Forever of the guide.
More Q&A to follow! Also, when more are written, I will organize them into sections like on the Main Guide.
