I just might use that logic...my husband will go for it if it means a new tv too!![]()
LOL..Well good luck!
Haha, I do have other methods of bribery in my arsenal...![]()
Ok first thing you need to do is flash the alternative recovery option within ROM manager so that you are using Amon Ra and not Clockwork, BTW dalvik cache in clockwork is in the advanced menu. I highly suggest you use Amon Ra though, much better recovery options.
CM is good but not if you like sense, ie all the widgets, etc. Mikfroyo, IMO, is the best ROM out there and you can get it here. A lot of people also recommend Myn RLS. I've tried them all and again IMO Mikfroyo is hands down the best, fastest, and smoothest out there. The community there is a lot of help as well. My id is the same in there. Feel free to log in there and ask some questions.
I would seriously try to flash a custom ROM before you unroot and see if that fixes your issue. Let me know if you have any other questions. Again the mik community is great and will answer your questions as well.
Ooooooo, I wonder what those are!![]()
Requires an entirely different type of guide!
Nick, I found this thread telling how to flash a custom ROM but it's from last August. Can you check it out and tell me if anything has changed? Thanks for all your help!
After much work I finally rooted my phone. It was great. I really did this so I could Tether. Recently, I made a mistake and updated and when I did I really screwed everything up. Tried to un-root but could not figure how to transfer to root of sd card. Followed instructions to a t but could not transfer. eventried to re load Unrevoked, came up with not finding radio. The phone re=boots all the time. Hotspot from Sprint keeps coming up with tether for root users. I should not ever updated. Now I cannot figure out how to un-root. If i could i would re-root. I did the unrevoked update is where it all started. Worked every angle for days. Any thought would be apprec.
What hboot version do you have and do you have s-on or s-off? Can you still get to recovery?
I have s-off and hboot 2.10.0001 and i can get to recovery
I just want to get my phone working again. i have lost my ability to connect to my Blueant blue tooth, which i had before, also, my "wifi tether for root users" is now all mixed up with sprints hotspot and neither will tether. I click on tether, and part of the time my phone re-boots. I felt that if I could wipe all out and start unrevoked all over again. By the way, my computer recognizes, and can now transfer to my evo, which i have had a problem before. Now I just want to tether and get my bluetooth back. When i initiate tether, i get the hotspot symbol and also the symbol for wifi tether. This is all screwed up. Worked fine til I thought I needed to download update. I rooted just to get tether. Thanks so much for your thoughts. Have a blessed day and weekend. Dewey in TampaWhich recovery do you have and do you want to unroot or just get your phone working again even if it is still rooted?
Does your pc recognize your phone when connect it?
I have a Wireless Tethering app (wifi Tehter) installed on my phone and while it works with my 4g service it will not work when just the 3g is on.
I noticed that mikroyo 4.61 also comes with the sprint hotspot, however i cant figure out how to get it to work. I have pressed opened the app but it simply does not do anything and while I am able to connect, I am never able to get an internet connection. (It also gives me a warning that I am not subscribed but can do a network etc.)
Also I tried to use the phone's usb to hook up the phone for tethering and I couldn't get that to work either. (When plugged in to computer it gives you an option)
So basically I have to have 4g on to get my tether to work. Id like to be able to use the 3g and save some battery life. Any ideas?
You were actually answered over in the mikmik site here. That would be your best bet on asking about mikfroyo ROMs.
I tried CryanogenMod & you're right, it did fix the problem. I want to try Mikfroyo now but I'm a little stuck.
I tried to switch to Amon Ra through Rom Manager & I keep getting an error that won't let me do it. Any suggestions on switching another way?
Do I have to use a new kernel with Mikfroyo? If so, which one (name & version) do you use/suggest?
Ok new question....
I oten check my speeds over 3g and 4g using the speedtest.net app and then while tethered to the evo I also check on my computers web browser. My issue is that whenever I go to test I am neve ron the right server. I am constantly in another state (I live in chicago) and I am always connecting to Michigan or Indiana etc etc. It is the same for both the phone app and the internet while tethering from phone. When I change the server to Chicago, I get MUCH faster speed tests. So I am worried that my phone is not connecting correctly and my speeds are suffering.
Is it possible that my phone is somehow not connecting to a local tower (or something) and I am connecting to something further away? I know it sounds dumb that it would even be possible to connect that far away.
Odds are if your cell signal is strong you are connecting to the closest tower. If you google search "how can i tell which cell tower i'm connected to" you will have a lot of results. I did that earlier when I first started to respond to you and was going to give you some links, but then my computer decided it wanted to reboot and I had some other things come up.
Hmm many times I do have a weak signal, on 4g I only get about 1 Bar sometimes no bars and I get a "4g antenna is on tap for service". Ocassionaly in some spots in my house I can get 2 bars and I acheive dl speeds of 5mb - 7mb. But that is spotty and doesn't always happen in the same spot. It seemed my reception was better before I flashed a custom ROM.
Ill google what you mentioned, I did search a bit for something like that before I cam here but there was so much junk I got discouraged. O)
If I was downloading at 5-7mb on my phone, I would cancel my cable internet and save about 60/month.
