NutOnTheLose
i have one last problem, i now cant download new apps or update existing ones... what can i do to fix this
You thought wrong!
You can either contact your carrier to unlock your phone or, visit your friendly, local, mobile phone store or there are a number of unlocking app's available on Play Store.
umm... as i have already stated the code given by either a phone company or a an app is the same code, trust me i ran through all of this multiple times over a lengthy period of time
when the imei doesnt match the network unlock code itz really annoying and how a company ***** that up is beyond me
Hi,
I'm a total noob when it comes to rooting but I'm taking the plunge! I have a question though, as I'm not sure which kernel to download. The version on my GT-i9100 is 2.6.35.7-I9100BVKJ4-CL681297root@DELL135 #2 and I can't find a KJ4 on the link provided. Would this one: CF-Root-SGS2_XW_XEF_KJ2-v5.0-CWM5.zip be correct?
Many thanks for the excellent guide: it's making a dummy feel like she might stand a chance of getting it right!
Hi,
Thanks!
kelis32: I'm just rooting to get rid of an internal memory problem I have so not too bothered about upgrading OS...yet! But if all goes well I may be flashing all sorts...
Hi and thanks for this guide, it has been very useful.
I followed the guide as stated and successfully rooted my S2 with the Siyah kernel. However, for some reason the home key no longer works. Can anyone suggest how to fix this? It is more of an annoyance than anything else and the phone seems to be functioning normally otherwise.
Here are the phone details:
Model: I9100
Android version: 4.0.4
Baseband: I9100XXLQ6
Build: IMM76D.XWLPT
CSC: I9100CPWLPA
Thanks
Hello and welcome to Android Forums u1tramagnus!
Congratulations on rooting your phone.
As for the Home key issue, have you tried the wipes mentioned in Step 4?
Is Siyah v6.0 Beta5 OK to use?
Siyah 6.0 beta 5 does not seem to be able to mount SD in NTFS probably so
does SiyahKernel S2-v5.0.1 work with Jellybean 4.1.2?
As far as I'm aware, The GS2 cannot mount its internal sd card using NTFS.
PhilZ kernel offers exFat support.
You may be able to load fuse.ko module with the ntfs-3g command, but I've never tried it personally. And even then, I think the best you could do is the format the external sd card, and not the internal.
See this thread for more details
If all you want is to be able to see an external NTFS card, then you can install NTFS Mounter This will enable your GS2 to see NTFS formatted cards when connected via an OTG cable
Hello, I'm new to the forums!
Flash a stock firmware for your device using Odin, and then hope that the repair techs can't tell it's been previously rooted otherwise your warranty will be void.How can I unroot if, say, I want to give the phone to samsung for a repair.
Using an app(like OTA RootKeeper) from the store is a good idea?
Hi guys Great news have rooted my samsung,went flawlessly,was sweating a bit but well worth it,any advice for what i should do now?i have backed up using CWM to my card,and downloading root explorer.![]()
how often does Siyah update their kernel? I really want to see V6.0 be out of beta at least. It is so crush prone.
