CapThrowback
Android Expert
The above portion on switching recoveries is what you want.k then am i on the right path this si what iam reading and it says nothing on how to get the the one you or them are talking about. unless iam just understanding wrong . this si what iam reading
Switching Recoveries
speaking of recovery i would really recommend that everyone switch to amon ra 2.3. it is a much better recovery then clockwork mod. you can get the recovery here:PC36IMG RA 2.3.zip
here are the instructions:
1.download the file.
2.rename the file by erasing the "_RA_2.3" part of the name so that it is only named PC36IMG. make sure not to add ".zip" to the name as windows hides extensions.
3.transfer the file to the root (that means not in any folder) of the sd card.
4.power off (you most likely need to uncheck fastboot. settings/apps/uncheck fastboot.) then press and hold power+vol down.
5.hboot should see the file and select yes to update.
6.select no to reboot because we want to go into recovery and make a nandroid backup.
7.select recovery.
8.select backup and restore and select backup
9. select the first three and wimax. the other partitions do not need to be backed up. always keep one nandroid backup with wimax keys backed up on your computer.
10.now you can reboot.
11.using a file manager of some sort or even through your computer via usb, you should rename or delete the PC36IMG file on your card. otherwise you will be asked to update every time you go to the hboot screen. you do not need that file any more.
and not to go off on a tangent and not to blam any one or any body and please not i dotn because i guess i am the genny pig on this an i am the first one that used the taco root part ot chage the boot loader but i lost every thing and it says that i would not
sorry going off a tangent my bad
And no, you're not the guinea pig for the TacoRoot method. I personally tested all of the methods in the 2.3.5 Rooting for Dummies thread, and was able to complete them successfully. And I never lost the data on any of my SD cards, so the rooting procedure wouldn't have done that.
I'm sorry you've been having so many issues with it, but we're all here to help you get back up and running as best we can.
