o.k. gotcha, well if you don't remember doing this step-- step 2 How to get Recovery---then you will for sure need to do it before flashing a rom.I am on step 3 flash a rom number 4
So before you flash a rom, go back to step 2
Sorry i done step 2 ADB command method the 2.3 recovery.o.k. gotcha, well if you don't remember doing this step-- step 2 How to get Recovery---then you will for sure need to do it before flashing a rom.
So before you flash a rom, go back to step 2![]()
I just dont know what to click on when i do the nandroid backup. there are many files in there do i just go with the ones that are selected already.
Ok there is:Ah, very good,very good then.
I would check the first 3 then, let me think, um, I think the only thing I leave un-checked it cache. You can check everything else. Maybe, to help me remember cuz I use a different recovery, is post the options so I can remember.
Thanks,![]()
Nice, thanks...Ok there is:
boot
system
data
cache
recovery
wimax
sd-ext
.android_secure
No problem. If you are sure you put it on your sd card, and you cant find it, it may be in a folder. Do you remeber the folder? If not you can go thru the folders and look while in recovery.Thank you so much and I do have one more question I cant find the file MikG v3.11 that I downloaded and put in my sd card folder. What can I do to find my rom?
If you want to freeze apps, then yes you need to purchase the "Pro Key"hey it is me again
do i need the titanium back up pro version
cuz it is saying sent i d/l the app. that the things i try to frezzz it says that it can only be done in the donate version so what do i need ot odo just buy the pro version
I answered that same question in post 267.as a person that has a rom or rooting a cust rom what ever you want ocall it can i cust my own rom ?
and do you have any other site or apps you think would be helpful to me sents i am a bigner at this ?
do you recommend any roms or kernals ?
Once you buy TB Pro, and you switch roms, download the free version and the pro version from the market....google will remember you purchased it already but be sure to download both or it wont work.if i get the key to the tb then if i wip my phone or chenge roms and lose it then how doi get it back
Well, if there is 2 of them, then just find the 1 and use it.I check everywhere in the flash zip from sdcard and could not find the file. what would happin if i download it again and put it on my sd card. There is going to be 2 of them..
Thank you so much you really know what you are talking about.Well, if there is 2 of them, then just find the 1 and use it.
Put in on the root (not in any folder) of sd card.
Are you still in recovery?
You can stay there and still put MikG zip on sd card.
Download Mikg to computer.
Plug phone into computer.
While in recovery, find the "usb ms/toggle"...hi light it and select it....this will allow you to transfer mikg from computer to phone's sd card.
When done transfering, click on "usb/ms toggle" to unmount phone from computer....wait a couple seconds and unplug phone..
Then you should easily find the MikG ROM.
Edit: it doesn't matter if you have 10 copies of rom on sd card...you just need one. lol
Thanks! Now tell me you got it to work and I'll be a happy boy!Thank you so much you really know what you are talking about.
Yes, Sir I got it to work!!!!!!Thanks! Now tell me you got it to work and I'll be a happy boy!![]()
I'm sorry, but what 3 files? The MikG rom file?now when i d/l thows three files one was a kernal i think so should i change the hernal then
not sure what three files you are talking about. is it the rom, kernel, and superwipe?now when i d/l thows three files one was a kernal i think so should i change the hernal then
yesand wants the rom has settled is is safe to update the apps
sorry i think this is the kernal you are talking about
Download the AnthraX kernel found here:
https://dl.dropbox.com/u/63060876/EVO%204G/AnthraX-2.6.38.8-REV_zzzTESTzzz009.zip
