k then am i on the right path this si what iam reading and it says nothing on how to get the the one you or them are talking about. unless iam just understanding wrong . this si what iam reading
Quote:
Originally Posted by
EarlyMon
Pffft.
And I bet you cats thought I'd forgotten about you - NEVER gonna happen, compadres!
OK - here's what you need to do to make revolutionary.io happen on a Mac, the free way -
- Install a virtual machine (VM)
- Install Ubuntu inside that machine
- Do revolutionary from there
And - we have good friend willy900wonka at XDA to help light the way:
[Guide]Using Revolutionary and Getting Soff on a MAC - xda-developers
Note - that's for the Evo 3D, but so what, there is really only one sky, if you get my meaning.
He has some picture instructions on how to set up the VM linked to -
How to set up Ubuntu Linux on a Mac -- it's easy and free - TUAW - The Unofficial Apple Weblog
The pictures are a little out of date - but don't panic - the newer version with the different options - just accept the defaults on the extra setup screens. (Except where given the choice to say Linux/Ubuntu.)
And the VM - although free - is exactly what I'm using on one of my business Macs to run a Red Hat distribution - to be honest, in some ways, I like it better than Parallels (it's like the old Parallels in that it's easier to configure and it just works). Best of all, it's free, and you get it from here -
http://virtualbox.org
And you want to get and use Ubuntu 10.04 (again - instructions are for Ubuntu 9, and wonka said to use 10.10, but 10.04 is the long-term supported version and should do nicely - but I think you'll be able to get the idea). Like any virtual machine setup, you need a CD of an operating system - or just an ISO image of the install CD that VirtualBox can mount as a virtual CD. And you can get that from -
http://www.ubuntu.com/start-download?distro=desktop&bits=32&release=lts
That's for the 32-bit version, I am *pretty sure* that will work just fine.
It's going to look like a lot of fol-de-rol but it's what you expect:
- Set up virtual machine
- Set up Ubuntu
- Set up Android sdk to get adb and fastboot (if needed)
- Trust the revolutionary.io wiki - public:revolutionary [RootWiki]
________________________After Rooting______________________
Life After Root
ok so you are rooted so now what?
here are some apps that you can now use, now that you are rooted.
- <LI sizset="256" sizcache06281079291499427="3">if you want to use a kernel:SetCPU for Root Users <LI sizset="257" sizcache06281079291499427="3">use this to backup your apps: Titanium Backup ★ root <LI sizset="258" sizcache06281079291499427="3">if you want to run linux commands:Android Terminal Emulator <LI sizset="259" sizcache06281079291499427="3">now you guys can make screen shots:ShootMe (Screen Grabber)
- this is not an app but it is something that you can use to make sure that you have a clean environment before you flash a rom. it is called vr superwipe:ZZZVR_SUPERWIPE.zip
what about bloatware you ask? well some of the apps are safe to delete. you can go here to see the list:
xda-developers - View Single Post - [WIP] /system/app APK's - Safe to remove list and functions now this list is from froyo so some apps are missing from the list. if you are going to delete apps i would use titanium backup and freeze the apps first.
DO NOT USE ROM MANAGER it is very buggy and creates more issues then it is worth. i would do everything manually in recovery. also this is a good way to get to know your recovery. you never know when something happens and all you have is recovery. as long as you have a working recovery you can pretty much get out of any trouble.
Recoveries
So what is a recovery and why do i need one now that i am rooted? in recovery that is where the magic happens. it is where you will flash roms and make nandroid backups as well as restore them. it is basically a mini os. your phone basically consists of three parts. it consists of android(gingerbread), bootloader(hboot), and finally your recovery os.
roms and flashable .zip files use scripts to tell recovery how to install the file. there are basically two kinds of scripts used. one is amend and the other is edify. most roms and flashable zip files use amend scripting. the problem is that clockwork mod 3 and higher do not support amend scripting. only clockwork mod 2.6, amon ra 2.3 and teamwin's trwp has support for both amend and edify.
Switching Recoveries
speaking of recovery i would really recommend that everyone switch to amon ra 2.3. it is a much better recovery then clockwork mod. you can get the recovery here:
PC36IMG RA 2.3.zip
here are the instructions:
1.download the file.
2.rename the file by erasing the "_RA_2.3" part of the name so that it is only named PC36IMG. make sure not to add ".zip" to the name as windows hides extensions.
3.transfer the file to the root (that means not in any folder) of the sd card.
4.power off (you most likely need to uncheck fastboot. settings/apps/uncheck fastboot.) then press and hold power+vol down.
5.hboot should see the file and select yes to update.
6.select no to reboot because we want to go into recovery and make a nandroid backup.
7.select recovery.
8.select backup and restore and select backup
9. select the first three and wimax. the other partitions do not need to be backed up. always keep one nandroid backup with wimax keys backed up on your computer.
10.now you can reboot.
11.using a file manager of some sort or even through your computer via usb, you should rename or delete the PC36IMG file on your card. otherwise you will be asked to update every time you go to the hboot screen. you do not need that file any more.
you can get older versions of clockwork mods and amon ra here:
Free File Hosting Made Simple - MediaFire.
also there is a new recovery from teamwin :
TeamWin Recovery Project (twrp) v1.0.3
this is what i was reading but got realy confued because it to me th a diff area
and i already have this file frm when i changed my hboot loader or is this a diff one
(WARNING: When you flash the Clockwork Recovery, you will permanently lose the Stock Recovery.)
OPTION 2 - Amon_RA (FLASHABLE)
AMON_RA
I don't have any details yet over Amon_RA, but use the official thread over at XDA for a complete lowdown.
[Recovery] [28-August-2010] RA-evo-v1.8.0 - xda-developers
and not to go off on a tangent and not to blam any one or any body and please not i dotn because i guess i am the genny pig on this an i am the first one that used the taco root part ot chage the boot loader but i lost every thing and it says that i would not
sorry going off a tangent my bad
