If you don't want to download an application like GPS Test you could just use the onboard test by going to the dialpad and entering *#*#1472365#*#* then go to "Test Application" and "Performance Test"
More info please... how is that?you can update it via odin (they've been doing it on xda).. so you don't need the OTA notification. so technically everyone can get their phone updated now. i'm a bit hesitant, since either method could brick my phone.
Ji6 installed... GPS sees 11 birds and locks on 9 netting 23ft accuracy.
OK, i now have Task manager icon as well as a HD Camcorder icon and of course media hub works.
What i dont see now is in Settings> wireless and network,...is where before i could make the network only work on 2G or have 3G working. That is gone. Anybody know where that is now? I had it on 2G only(to save battery) before i did the update so i hope it will be able to get 3G...but i havent seen it yet.
OTA or ??
MMS, no! Battery drain, cant tell yet. As mentioned in another post, in Settings> Wireless and Network>Mobile Networks,...the option to only use 2G is gone now to save battery.
I used that a lot when i wasnt doing anything but getting emails. Had it checked before i did the update. Hope i can get 3G now and havent seen it yet but im at home using wi-fi.
i replied to your other post regarding 2g/3g. it's still there but renamed to 'gsm only' and 'wcdma only' and added 'auto mode' which was selected by default for me.
link
They send it out in waves so every phone on their network isn't downloading something at the same time. They said it should all be out by the end of October.so samsung is sending out the OTA update in series of waves? so........ what? theyre sending out like 100 updates to diff phones? and i know nobody knows, but how long would it be until the last one is sent? (BESIDES NEW BOUGHT PHONES)
From what I read on the Captivate forums the update they got disabled that key sequence.
Found it Here;
http://androidforums.com/samsung-captivate/182773-gps-after-update-same-better.html
I think the only way to access it is to use Anycut and make a shortcut to the lbstestmode.
Plus i Also read that some of the Settings that you could change are disabled as well.
here in ny i haven't gotten the update
Find your original message and count about 8 messages up, or just look here:More info please... how is that?
