Calixto2534
Also my carrier is sprint
I do not understand how to check for a good fastboot connection. so do i go to command prompt and search the coomand?
Hi Guys, I hope someone can help me.
I have D803 running Optimus G3 Rom with no problems. I wanted to change the rom to Slimkat, just to try it. So I backed up my existing rom in TWRP and flashed the Slimkat.
Everything was OK till I desided to go back to Optimus G3. While I was in the Slimkat I chceked for newer TWRP and reflashed.
After rebooting to TWRP and restoring Optimus something happened and the restore did not work. So now my phone reboots to TWRP and that's it.
I have tried everything for 2 days from LG mobile support tool to pushing new rom via ADB sideload. LG mobile tool runs till 2% and stops, ADB sideload pushes the rom (OptimusG3) OK but at the end of the installation it say "Set_metadata_recursive: some changes failed".
Also I tried to use fastboot commend to flash aboot and other files like above, but I can only do ADB commands, fastboot is not working.
I checked the drivers and my phone seems to be recognized properly in Device
Manager in win 8.1. I also changed computers and used win 7 and no fastboot either. One thing I notice, win 7 computer had problem installing drivers in bootloader.
Like I said it's over my head and I've tried to solve it for 2 days and no luck.
Hopefully someone can point me in the right direction.
Thanks in advance.
I end up solving the problem. I fallowed the instructions using the dll file and tot flasher and used D803 firmware and dll. Worked like a charm.
Sparky15
hi, i have the same problem with my ls980 ( sprint )
i flashed both aboot.img and laf.img. when i try to boot into download mode it shows a screen with a blue square saying download mode then it switches to fastboot.
any ideas?
much appreciated.
Does your device show up in device manager, even as an unknown device? Do you have the LG United drivers installed onto your PC? You'll need those for recognition in download mode.
no it gets recognized as a android sooner single adb device. i can flash it with the files mentioned above and thats how i can flash it.
the download mode doesnt last more than 1 second. t quickly switches back to fastboot without pressing anything. i dont even have the chance to check if it gets recognized o not in download mode...
yes i did miss that post.
alright so i uninstalled the drivers and installed the drivers you posted to make sure that its not a driver problem. the result, the same drivers as before and the phone as explained before it starts with a white square and download mode and quickly jumps in the fastboot. no matter what i do it jumps in fastboot.
any ideas?
thats interesting..
i did try that and i got this in command.
downloading 'boot.img'...
OKAY [ 0.566s]
booting...
FAILED (remote: dtb not found)
finished. total time: 0.734s
on the device i got a
error: getting device tree address failed
dtb offset is incorrect kernel image does not have applied dtb
hey not sure this thread still open but..Whew, that was one of the trickier ones I've seen in awhile. Remind me to send a scathing email to Sprint to be more haxor friendly in the future.
Ok, let me find some files and write up the next step. Will post in a few.
have followed instructions to try and get lgg2 from fast boot mode to download mode
have successfully got device from unknown to android on win 7
my main problem is when i v up and usb in it flashes for a sec download mode then the screen just turns back to fastboot recharge .last line is fastboot host
i can fastboot reboot and phone will reboot
now i am fust accumulating a folder of tools and am lost
LG G2 32GB Unlocked & Rooted Smartphone with Android 4.4.2 KitKat Installed Featuring OptimusG3 ROM
i feel im close just need that extra help please regards scott
