Ok I've done it. Flash Tool worked.
But it got to 94% then said "usb port open fail"
What can I do?
The device started normally and there is no issue I think.
Hello iowabowtech,
I just escaped from the problem-stuck with fastboot after following wonderful guide..
I got download mode and flashed stock kdz file and flashed successfully without error.
But after flashing is complete, now stuck with lg logo...
I tried many times the flashing...and every time successfully flashed..(in both ways normal flash and cse flash)- flashing success...
But still at lg logo...
I tried to get hard reset..by pressing volume down+power keys..but there is no more factory reset window..same lg logo appears.
Please solve my problem...
My device LG G2 D802 32GB.
I have got the same problem with my G2Verizon 32gb,everthing works as you have said it,but when i do:
ow with a working fastboot connection, and the phone connected to the pc showing fastboot on it's screen, open command prompt and change directory to the sdk-tools folder on your C drive so...
From there flash aboot:
fastboot flash aboot aboot.img
Next boot laf:
fastboot boot laf.img
Cmd says: fastboot flash aboot aboot.img
target reported max download size of 1862270976 bytes
eroor. cannot load "aboot.img" : No errors
the same at laf.img
Edit:When 1 press all 3 buttons i came into the Hardware Key Control
Edit:It came a little window for 2 seconds where stands DownloadMode but then it switches to fastboot
Yesterday evening i made big shit.Now i doesnt go into Fastboot,it bootes and then cames the LgLogo,but then it stops?What could i do,Im on dispairing....![]()
i downloaded them and flashed them again .
i tried the boot laf.img. i got this error now...![]()
and he same error on the phone as mentioned before![]()
C:\ls980>fastboot boot laf.img
downloading 'boot.img'...
OKAY [ 0.551s]
booting...
FAILED (remote: dtb not found)
finished. total time: 0.718s
C:\ls980>
Ok,i found out that when im in the BlackScreen Mode,the phone is shown as qhsusb_bulk what should i do now?
Same situation here... It seems that this procedure is not working with 980 32gb version...
Is there a solution for this particular device? Please help me
If you're on verizon, see the post directly above this one for the files you need...your overall procedure will be a little different but the files you need are the same and those are the 26a aboot, boot and laf. Go ahead and flash those three partitions if booting laf is not working for you. So...
fastboot flash boot boot.img
fastboot flash laf laf.img
When you download them, make sure the file size you end up with matches what is listed on that page. When you flash each one, pay attention to the file size of each and make sure they match what fastboot reports back (it tells you the size of the file it just flashed when it performs that function). Make sure they are correct. As long as you do that, it's fairly safe to just flash all three.
Make sure you're using the 26a aboot, boot and laf files assuming that's the firmware you were on at the time of failure which is the case for most VS980 people right now. When you're done with the flashing of those 3 partitions, UNPLUG first, then turn off the phone by long pressing power for no less than 15 seconds. DON'T stop holding the button if you feel a vibrate at less time...continue to hold for a total of 15-20 seconds, then release.
Once off, press and hold volume up while at the same time connecting the phone to the PC. You should get download mode now. If so, use the instructs in the above post to return to stock using LG Flash Tools and the 26a tot and dll files.
Good luck and ask if questions.
Ok, yesterday i flashed with the XDA tutorial the 11a Files,the wrong(i wondered myself why it didnt workugggggg,sorry
When i now plug in my phone in linux,my phone screen goes to a brigt dark to a dark dark,the whole time.That the Tut works,it should be on a bright dark.The Pc regonizes the phone,then not,then the pc recognizes it again.....What could i do?In windows doesnt happen that.
WOW, no download mode, I was crying when the phone has reboot normally![]()
Now I don't want to switch off nevermore!!
How can I put while the phone is on a right recovery for flash a rom?
Thanks!!!
Hmm,but in Windows everything works?
