new optimus
Android Expert
Why does att have better indoor reception than t mobile considering their both gsm? Is it a specific band that is better?
I love t mobile. I feel they are really looking out for their customers with all their recent changes but damn, fix the indoor reception. Something I'm sure everyone struggles with at some point. It's freaking aggravating having to go outside just to use my phone. It used to not be this bad :/
It also depends on signal strength, Att has the towers in locations that make the signal clearer, plus how much power is put to the signal, to amp it up.Frequency/Wavelength are a big reason why. The lower the frequency, the farther the distance it can travel before degrading and the better the building penetration is. However, higher frequencies allow faster data speeds. AT&T 2g/hspa is on the 850MHz line and most LTE is on 700 MHz. For T-Mobile, 2g is on 1900 MHz, HSPA is on 1700/2100 or 1900MHz while LTE is on 1700/2100 MHz.
This is why buying a large portion of the 600MHz spectrum next summer is a crucial move for T-Mobile.
T mobile towers are spaced too far apart, hopefully this will change, and they usually run the power levels lower, there are both pros and cons to that.
