jmar
Nexican
You bad indicator, you.I'm on Faux, but I don't think I have LTE in my area, so I might be a bad indicator.
Merge complete. Once you get your device all sorted and have the time, please reorganize the info in the OP. I'm sure users will appreciate it. Again many thanks for getting the ball rolling here. I knew of the mod but wasn't really motivated to do it until your post.More complications. I can't get the change from wcdma to lte/gsm in the testing menu (*#*#4636#*#*) to stick. Why don't you go ahead and merge our posts? Eventually I'll have my device running properly, and at least I'll have some answers for anybody running into the same problems.
Did you go back to the .48 radio? While on that radio the lte will not stick, part of the update I believe.More complications. I can't get the change from wcdma to lte/gsm in the testing menu (*#*#4636#*#*) to stick. Why don't you go ahead and merge our posts? Eventually I'll have my device running properly, and at least I'll have some answers for anybody running into the same problems.
I was reading about a rom that has pie, and other features that people like from PA but it works with the .33 radio, If I can find it again I will post it.I'm a big fan of pie on PA (I hate the brief moments I ever don't use it). I've seen a couple apps on the play store, but nothing like what I'm used to. I think I've read that it can be installed on other roms? If not, I will have to think about what is more important to me. I'm try aokp tonight.
Also, I'm positive I'm on 33, but it is possible I accidentally flashed 48 instead. Thanks for the info!
I think that is it.Could it be xylon?
The line: ro.ril.def.preferred.network=9 is correct. I have this mod confirmed working on my N4 as well as my Wife's N4. We live in San Jose so I can say with great certainty that using an underscore instead of a period in that specific line may yield an undesired outcome. Not sure what it would be but why risk it?Did you go back to the .48 radio? While on that radio the lte will not stick, part of the update I believe.
I have heard that stock rom with .33 radio will cause no audio in calls, and the kernel you mention is also on that list, the dev will not change it for liability reasons I think, read on xda.
In jacksonville fl no lte yet, I did this mod a last week, found it on xda though on the version I found the line with ro.ril.def.preferred_network=9 rather then . I wonder if it makes a difference.
in mobile networks I see lte/gsm/wcdma. So I know its looking for lte first.
OP looks great. Good job organizing all the info and making it super user friendly. Thanks as well for the kudos.Back up and running! Working on editing the OP now!
On T-Mobile LTE, in-call audio will not work with stock ROM and .33 radios without doing a recently developed hack.
Post #445
http://forum.xda-developers.com/showthread.php?p=40244956
Been using LTE in Vegas since March and it's been a lot more battery efficient than HSPA+ 42.
Hey y'all,
Wanted to share an experience with you related to this hack.
SPOILER ALERT: This hack doesn't play nicely with all N4s!
My wife and I each have N4s. I used this hack to enable 4G LTE for both phones.
Good to know. Did you order them at different times, or is one older than the other (and if so, which one)?
