Root [THEME] Honeycomb Hybrid 3.0 No CIQ (Updated 10.19.11)
blue2107
Well... Here it is. This is what I've been working on for the last month or so.
To install you need to already need to be on Shabbymod 0.9 w/CWR
This is a two step process (much like the newest version of simple blue/green). Which only means you have to flash two zips. I have tested this from a freshly rooted Shabby 0.9 install and it works with no "Force Close" pop ups or bootloops.
With that said IF you want to do a factory reset. You need to flash step_1_f.zip again afterward OR you will get bootlooped. Then flash step_2_j.zip after a normal boot up.
Highly Advised Pre Install:
1. Create a backup image before you proceed. Please it only takes like 3 minutes.
2. Wipe your "cache partition" and "Dalvik cache" from the Clockwork Recovery Menu Before you flash this theme. Especially with the No CIQ version to help avoid any force close errors.
To Install:
1. Unzip Honeycomb_Hybrid_RC_1.zip
2. Flash step_1_f.zip
3. Let phone boot up normally
4. Flash step_2_j.zip
5. Let phone boot up normally
6. ENJOY
Note: I've included two files to help with any issues afterward.
1. Market possibly stuck "downloading" apps.
2. Bootlooping after a factory reset.
This theme includes the following mods:
- Removed CIQ (Thanks Bloodawn)
- Power menu & toggles
- Sped up animation delay ( so phone seems more responsive)
- Custom sounds for: Camera shutter, Video record, Usb connect/disconnect, and selection tick (when typing or choosing a selection from the settings and such)
- Other themed parts not shown in screenshots
Thanks to:
hroark13, Interdpth, Shabbypenguin, Blooddawn, New Optimus, Obsession XYZ, and UOTK
Screenshots w/more info below
Lockscreen:
- Removed "Boost Mobile" carrier logo
- Rearranged for a more uniformed look
- Changed some font styles
Home Screen and Settings:
- Added Honeycomb type icons to:
Gmail, Deskclock, Calendar, Gallery, Messaging, Settings, Camera, Contacts, Calculator, Google Search, Phone, and Market.
- Custom notification icons for:
Gmail, Deskclock, Calendar, Messaging, Phone, and Market
- Themed: Google Search, and Analog clock
- Moved cell signal to right corner (only because having the wifi and cell signal next to each other seemed confusing).
Then from right to left is:
WiFi, Battery, Alarm, Sounds & Vibrate, ect...
- Added thin progress bar for: Volume and Downloads
Applications:
Phone:
-Totally redesigned the layout of the in-call gui
-Themed pull-up dialpad and sliders
Scientific Calculator:
-Pulled from HTC build and simply themed
Camera:
-Changed shutter sound
-Themed
Deskclock:
-Totally redesigned layout
-Colored temp for weather widget (red/high blue/low)
Keyboard:
-Themed
P.S. looks much much better on phone screen
If you like my work. Please make a donation (because every little bit makes a difference) and help me buy my wife something nice. Help me show her that the android community is a giving community.
Thanks.
If I have forgotten anyone or anything please forgive me. Will update soon.
Reserved for updates, bugfixes, and other shtuff
Update: 10.16.11
- Added No CIQ 3.1 MOD (By Bloodawn)
Update: 10.19.11
- Fixed Missing parts of the No CIQ MOD (RC2)
Note: Market was kinda buggy and did not want to download after flash of (No CIQ MOD) and got the " Google talk authentication failed " error. So I updated the "Market not downloading" file to include a wipe of the cache partition and dalvik from Clockwork Recovery.
Please report any Issues/Bugs and I will update the OP asap.
Thank you
Looks really good, I might give it a whirl some time next week if I can find the time.
Is CIQ removed on this?
Followed the instructions, no problems at all. You can tell a lot of work went into this theme, I am impressed again by your efforts. The Theme is great.
2nd response: Phone is incredibly responsive, all actions are performed much quicker. This theme is more than eye candy.
Nice job Blue! I have been waiting for your theme. Looks great! I paired it up with the ADW honeycomb theme since ADW is my launcher of choice. Thank you!:)
Blue, you have done a really really good job.... ive been working on my honeycomb theme for a few weeks and now i think i will just forget about mine and use yours. i do have some icons i would like to change up a bit but thats just me. But i just wanted to tell you..... Good job, I think this is the BEST theme yet!! i give you an A++++++ lol:D
