Fabolous
Superuser
anybody get the battery percents to work???
The file is still shot, sorry, I didn't get to it this weekend
The file is still shot, sorry, I didn't get to it this weekend![]()
has anyone tried putting the stock fonts back on using the manual method in adb? anyone have the cmd lines to put in to do this?
su
mount -o rw,remount -t ext3 /dev/block/mmcblk1p21 /system
cp /sdcard/theme/fonts/* /system/fonts/
mount -o ro,remount -t ext3 /dev/block/mmcblk1p21 /system
reboot
This is, of course, providing you have put the fonts folder in the path as listed above.
can I just erase the one in the sdcard/theme folder now and replace it with the one from Stock_Fonts_Froyo_DX.zip\system\fonts? then do the adb commands??
Well, I'm officially hoping the file fix from Fab will fix my black clock. I would say it's just flat crazy, but trying to get the clock fixed from trying 30 different things is just flat crazy.
Goodnight all.
i assume you tried reinstalling everything again right? cause when I installed it my clock was white
I installed the theme on 2.3.15 leaked, but how do I get the Bluetooth toggle, Wifi Toggle etc to look like they do on the screenshot on the first page? Mine still look stock.
Also, I'm not getting the transparent overlay for the launcher pro icons at the bottom.
Still not sure how you got the translucent window around your home screen actions at the bottom either. I'm referring to this picture.
http://lh5.ggpht.com/_UTCnOJLqdxs/TGEIvH6PrJI/AAAAAAAAAlw/LK-UWbNzv58/s640/nexthemewidgets.png
are you using launcher pro? if so hit hard menu button>preferences>appearance settings>dock background
there are several to choose from in there
N/M it's just power control widget.
Is there an icon that shows up for when gps is turned on? I can't figure out if isn't there because of rubiX or because of this theme.
Edit: It's rubiX that causes the gps icon to not show up. Probably the same for the Wifi icon also.
