Fabolous
Superuser
For some reason even though I installed this NexFro, My phone is still booting up with the DarkEdge UI screen...
Then I don't think you did it right
How did you install this?
I'm sorry...I may have spoke too soon about the wifi. This is pissing me off.
I am having great luck with 1.0.1....came from CM 5.0.7.1...wiped data, cache, partition, and boot multiple times....
Haven't had the issues others have had so far with wifi, etc.....using P3's 1200lv, which doesn't seem to have "broken" anything....
Even with the Froyo BB now out, I'm sticking with NexFro....I like the look and is running super smooth....thanks Fab!!
On another note, I fixed the f*kn wifi issue.
Is NexFro using Petes Bugless Beast Froyo release or just a froyo release??
Correct me if i'm wrong, but I believe that right now, it is just a froyo release (frf57, if i'm not mistaken)
He was on his way home from a trip last night. You should expect BB to be themed some time this weekend probably. Maybe even tonight.Correct me if i'm wrong, but I believe that right now, it is just a froyo release (frf57, if i'm not mistaken)
Thanks.
I really hope Fab makes a new NexBeast using Pete's Rom. Or we can get a nextheme for Petes new Rom. I tested his rom last night once i was finally able to get it downloaded and its the fastest most stable froyo rom i have used so far. Just needs themeing.
awesome....2 things....
1) battery seems to be reporting in 20% increments, don't know if that's been mentioned yet...
2) in the new music player, how do you get the album art?
Opps, meant to post this here, but accidentally posted it in the BB thread. So I'm just pasting it here:
Sorry if it's already been asked, I don't have time to read the whole thread right now. But has anyone installed this NexBeast and just restored their data (using CW or SPR) with no issues? That's how I updated from the original 2.2 leak to FRF57 and didn't have a prob, so I'm assuming it won't be a prob with this, but want to be sure before I try.
Also, are their any other kernels available for 2.2 besides the ones listed in the OP here? I'm running the 1.1 GHz (labeled 1.25 GHz) and battery life has tanked from Chevy's 1.1 LV kernel I was running with NexBeast 1.0.1 (2.1) before I installed Froyo. So I would like to use Chevys' kernels if possible.
Thanks!
Just to make you aware this isnt based off of petes bugless beast rom. so its not nexbeast. this seems to be a rom Fab put together based off the 2.2 base rom
Opps, typo on my part. I knew that, was just thinking of NexBeast since that's what I was running before 2.2.
