The~Skater~187
Android Expert
Just thought I would put this out there for those of you that are not a fan of your current baseband and want to go to ej06, fa19, fe16 or vise versa without all the hassle of reflashing Roms, Kernels, Themes, or whatever.
If you want to switch just your baseband, all you need is:
-A version of Odin with the desired baseband that you want.
To Install Baseband:
-Put your phone into download mode
-Connect your phone to your pc
-Open up Odin and select one package
-Select Your Ops
-Select phone.tar
-Hit start
As soon as Odin says reset it is safe to unplug your phone from your pc and enjoy your new baseband.
-Select Your Ops
-Select phone.tar
-Hit start
