Root Universal Eris Root for Dummies!
Okie, I'm having a small issue of storage space....or lack thereof. It's important to note that IRL, I am a major packrat of the "I might need that!" sort. So, I'm disinclined to delete things. I see on xda that there is an Apps2SD. Will that help my storage problems? Is there anything special to know about using Apps2SD? Is there a ROM that includes Apps2SD already? Or will I need to install it on its own?
~Amy~
It sounds as though Apps2sd is exactly what you need. There are plenty of ROMs available that have it by default, you will need to partition your sdcard for this to work so backup everything off of your sdcard prior to partitioning as it will erase everything. Take a look at XDA for plenty of ROMs and if you like the stock ROM T2noob has a ROM posted here with apps2sd already caled plain Jane 2.0 I think.
Edit: T2noob's ROM linked
http://androidforums.com/all-things-root-eris/115419-rom-plainjanet2-stock-2-1-oc-a2sd.html
Try booting back into recovery and do another wipe/factory reset along with a wipe dalvik-cache, then reboot.
K so i pulled the battery, booted into recovery and did both wipes. When i rebooted, it loaded the usual skateboard boot screen. It then vibrated 5 times and remained on the boot screen.
This post is the greatest I have ever seen. There is lot of work done on Moto Droid but Eris kinda left alone for a while. I used a leak version to get to 2.1 and then could not get the root to change it. Today finally the curse is broken and I got the Froyo.
Thank you! Thank you!! Thank you!!!
Before you get started, please review this checklist:
1) Did you choose a ROM, download it to your SD card, and check the MD5 signature/file length on the copy of the file on your SD card?
how do i check the MD5 signature/file length on the PlainJaneT2 ROM that i downloaded?
Check out this thread for how to do it: http://androidforums.com/htc-droid-eris/138831-verify-your-files-md5-checksums.html
Unfortunately, I do not see an MD5 sum listed for that ROM in the developer's thread for this ROM on XDA. These checksums should be posted by the devs so you can make sure you've got a complete, uncorrupted, and proper version of the file in question.
Perhaps someone else that has downloaded this custom ROM could publish their MD5 sum so you could at least compare that? Anyone?
Or, at the very least, you can verify that the file you downloaded matches what you placed on you /sdcard (that helps a little).
Great post my friend. I've been pondering root for a long time now but I wasn't willing to take the chance. With your walk through specifically categorized "For HTC Eris" I was able to root my phone with no problems.
In need of help....just rooted last night and can't open any ROM zip files. They are there, but it keeps saying "can't open".:confused:
sa,
I don't think that the "toolbox" executable of the HTC-shipped ROMs supplied a "md5sum" function - so folks that are getting started rooting (i.e., don't already have root) can not run "md5sum" from their phone without installing an app to do that.
There is an alternate way to check that a ROM is at least "intact" - that is, not corrupted or truncated. It does not verify authenticity, however, and it also involves the PC.
That method is to use "jarsigner -verify ROM_name.zip" on the PC ("jarsigner" is included in the JDK - if you set up your PC with the Android SDK, the JDK is required as a prerequisite) It unpacks the zip and compares the SHA1 signatures of every file in the manifest.
This does not verify that it is the same ROM as that published by the author, as the signing keys used by all the "cooks" is the same key, and widely available (not really private any longer) - someone could pick apart a ROM, put some of their own stuff in it, re-sign it with the same keys, and it would pass this test. (The probability of this happening at the download link provided by the ROM author is pretty low, although it would be much easier if someone was "hosting a copy")
I suppose you could do this check on a PC, and if it passes, then look at the length of the file in bytes (on both the PC and the phone); if they are the same, the probability of them being different is pretty darn low. Doing things this way is not as good as performing the MD5 check right on the phone, but it is better than nothing at all.
But, it does indicate that the ROM file will pass the "verification" phase of the ROM install by the Amon_RA recovery boot.
As a practical matter, though, the problems most folks have with "corrupted" ROMs are due to far simpler problems (rather than single-bit errors):
- Their OS "hides" file extensions (Windows) or Automatically unpacks .Zip files (O/S X)
- Their initial download times out, and they are left with a "short" file.
- They copy the file to their SD card via the USB cable, and fail to properly eject/unmount the SD card, so that the file ends up short/corrupted on the SD card, even though it was intact on the PC.
In the most desirable scenario, the dev would publish both the exact file length (bytes) and MD5 signature when they post a download link. Because it is essentially impossible to make a single-byte change to a file to produce the same MD5 signature, publishing the file length is usually regarded as optional - verifying the MD5 signature validates that you have the same file, even if the file length is not stated.
The thing which should be pointed out is that it is not possible to install a corrupted ROM - it won't pass the "verification" check performed before any files are being flashed.
My guess is that folks who experience boot-loop symptoms after installing a ROM have this happen for a couple of reasons:
1) They failed to perform a wipe in Amon_RA (where required) prior to the ROM install, or
2) They used a ROM which expects a partitioned SD card for a2sd, or
3) They used a partitioned SD card with an ext format (either ext2 or ext4) which is not supported by the target ROM, or
4) The ROM developer kitted their ROM so that it was necessary to flash a (full-wipe) base ROM, and then overlay some update flashes to get the correct behavior, and the user failed to add the overlay flashes, or
5) They flashed their ROM with a very low battery - say 50% or less, and the installed file really was corrupted (in NAND memory, but not on the SD card), or
6) They had previously rooted and used A2SD, and have some apps in the ext partition on their SD card which are completely incompatible with the new ROM.
(Note that ROMs which are pre-configured to start adbd up on boot will have a shell available which comes alive about 8-9 seconds into the boot - in these cases it is sometimes possible to observe the exact cause of the boot-loop by using either "logcat" or ddms: the kernel is actually booted, but the looping is occurring in the initial housekeeping stage of the Android boot process. But, this is sort of advanced for a casual user - and, as I said, I want this thread to concentrate on phone-only techniques)
I put the suggestion to "check the MD5 or file length" in my original posts mostly so that folks without SD card readers would not end up wiping their phone and then finding out afterward that they had mangled their ROM .zip file when downloading or transferring it to the phone. (Even that is not a disaster, because they would have the "USB-MS toggle" functionality of Amon_RA, but that was a detail that I touched on only lightly).
eu1
Quick, maybe dumb question. But how do I tell if I'm rooted now? I didn't flash a ROM when I did this.
Sorry, think I got the answer.
eu1,
Thank you (yet again! :)) for a highly informative and relevant post! I appreciate all of the bonus and related information too.
It also occurred to me at lunch that some of the custom rooted ROMs might also not have the MD5 sum utility in them or their busybox version is not playing "nice" (i.e, varkie is getting "illegal instruction" for some reason). Your point is well taken...(btw, I'm trying to build my first Android app w/help from jcase and a simple MD5 summer is my target idea--lots of stuff to learn...).
I think I've spouted the mantra of "check your MD5 sums" to folks mostly to make sure they're obtaining their files from reputable sources (remember theUnlockr "incident"? :eek: (edit: although if theUnlockr had published the MD5 sum, it would not have dissuaded folks from downloading the non-root (2.1 leak) ROM, if anything, it would have made them feel more secure that it was the right file))--i.e., making sure they are getting the file that they expect to.
I will include a link to this post in the MD5 sum thread that I made.
Thanks again!
This is awesome, as I've got the newer bootloader which couldn't previously be rooted. Taking the plunge now... I've followed the first two parts and successfully gotten the blue screens and the "you've got root message".
which folder exactly should we be moving the roms into? the tutorial says the "root" folder.
I'm trying senseable, so I moved the zip into the root of the card after checking the hash, then using es file explorer I tried to move the zip into the /sdcard/root folder, but the file "cannot be copied".
should I leave it in the /sdcard folder (or root of the folder when mounting on pc) or am I doing some really wrong?
Leave it in /sdcard ; that is the root folder (when viewed using a file manager on the phone)
( Note that if you downloaded the ROM directly to the phone using the phone's browser, you would move it from /sdcard/download to /sdcard in exactly the same manner that we moved the "gscript.zip" file in the example given )
You will know you are doing the right thing because when you pick the (Amon_RA) main menu item "Flash zip from sdcard", your file will be listed.
When using the PC, it will be the E:, F: or similar drive letter.
If you copy the file from the PC using the USB cable, make sure you have correctly dismounted the Eris from the PC by using the "Safely Remove Hardware" control in your (Windows PC) system tray first - before you toggle off the "Disk Drive Mode" on the phone.
eu1
I'm a moron, thanks.
This is a fantastic guide, the amount of detail is very helpful
booting into my first ROM (senseable 3.1) now. The whole process took about 45 minutes all told, I could do it again in about 5 now that I know how.
Ok, so I'm giving this a shot.
I'm running in a problem at figures 13-17. I'm extracting the gscript.zip file into the gscript/ folder, but when I click "OK" I get a popup that says "counting files size", but the status bar doesn't move. That screen minimizes and i get a popup saying "extract is done". I then click the / button and then click on "SDCARD", but there is no "gscript" folder.
What am I doing wrong?
Beats me.
Because I can't see what you are seeing, I have to guess.
I just did the extract process about 10 times, and I can tell you that not once does anything appear on the screen which says "counting file size". I see something similar to figure 12, where the green progress bar moves (quickly!) across the screen - there are only 4 files after all.
A very small popup briefly appears on the screen (perhaps for 1 second) which says "extract is done" after extraction is completed.
Here is what I would do if I were you.
Using ES file explorer, delete the "gscript.zip" file from /sdcard
Then, download it again using the phone's browser, and repeat the cut-and-paste steps used to move it from /sdcard/download/gscript.zip to /sdcard/gscript.zip.
Before you do the "Extract", long-press on gscript.zip and scroll down and select "Properties". You should see that its' size is listed as
Size: 3.73 MB (3,915,189 bytes)
I don't really know what is happening in your case - it could be that the download was corrupted somehow, or it could be a simple usage mistake on your part.
If you want, you can certainly experiment with ES File Explorer and other zip files to familiarize yourself with how it is supposed to work - grab some (smallish) Zip files and extract them, and then poke around in the folders that are created by the extraction (using ES File Explorer), just to get familiar with how it works. If you are making a simple mistake, you will probably discover it by becoming more familiar with how ES File Explorer behaves.
If you can't get this to work, there is an even easier method of rooting available (but it doesn't come with lots of pictures and instructions):
http://androidforums.com/all-things...is-app-apk-no-pcs-no-scripts-needed-easy.html
It's an app that does the work in one click (released about a week or so after I released this method). It is "charity ware" - the developer asks that in lieu of payment, you make a charitable donation.
Good Luck
eu1
If I don't want to install a custom ROM am I done after figure 31? Do I even need to boot into recovery or can I just jump into my now-rooted phone? If I simply reboot I'll still be rooted and be able to turn my phone into a wifi hotspot right? (that's the main reason I'm doing it) So could anyone please answer my root question, then point me in the right direction to the best way to tether for rooted users (I'm pretty sure it's a simple app) and perhaps some recommendations of ROMS should I ever want to install one?
erisuser1, thank you so much for this tutorial! I would have never rooted if you hadn't explained it so well.
I liked my Eris before I rooted, now I LOVE it.
Thanks again!
Well, by "Congratulations, you have root" I meant that you have nearly full control over the phone at that point - but nothing has been changed except for the Recovery Boot partition. The main O/S ( boot, system, data, and cache partitions) have been essentially untouched at the completion of Fig. 31.
If you want to keep what you've got, but add root capability to your current HTC ROM, what you want to do is an "update flash".
This proceeds more or less like the set of figures following fig. 31 with one exception: YOU DO NOT PERFORM A WIPE (fig 38) FOR AN "UPDATE" or "OVERLAY" flash.
So, what you do is you download the "engtools3.zip" file from this post over on XDA (thanks Jcase!):
How To Install Engineering bootloader FOR LEAK ROOTERS - xda-developers (see the link near Step 5)
and then flash this (engtools3.zip) file using the Amon_RA main menu item "Flash zip from sdcard"
This installs exactly three things to your phone (in addition to whatever is already there):
/system/app/SuperUser.apk (Super-user App)
/system/bin/su (su executable)
/system/bin/flash_image
That will install a minimum set of root tools for you to begin fooling with your phone.
eu1
PS0 It is absolutely reckless to skip the initial Nandroid backup of your existing ROM.
PS1 With some searching (code.google.com) you should be able to easily find the Wireless Tether app (.apk)
PS2 A lot of dev ROMs install an app called "busybox" into either /system/bin or /system/xbin, and then create symlinks to it for all the different functions that it can perform. This is NOT done by engtools3.zip. You might find that many scripts that get used on root ROMs will not work for you, because they presume that many common tools provided by busybox are "in your PATH".
PS3 You will not be able to overclock with the stock kernel. You need to replace the boot partition to do that.
Finally got it working this morning thanks to EU1! I guess I got a bad download or something.
One question: Once I've flashed the .zip files, can I remove them from my memory card or should I leave them be?
You can delete them if you want...
What I do is move them to a subfolder (called otherstuff) in my download folder so they are out of the way (and out of sight for custom recovery), but I've still got them if I need them. Plus, I've got plenty of space on my /sdcard, so no worries there.
I've read over this thread and a few others several times and am ready to root ... but ... my phone is stock 2.1 OTA.
Should I hold off for now because of the "possible loss of 3G" issue that Trident posted about?
Right now, all I'm looking for is longer battery life and less lag when I'm at work (out in the boonies)
I mainly surf the 'net and text since the phone part of the friggin' phone is a joke! I'm hoping a new ROM will take care of that annoying problem, but I can wait to flash one - if it's suggested.
What say You(s)? ;)
P.S. Just realized that I haven't seen "3G" in the notification bar in days. Is there any way to check on it? I can send and receive texts.
The "factory reset" performed by a stock HTC phone alters more than gets changed when you perform a ROM replacement during rooting. Rooting certainly does not touch the non-volatile memory areas of the phone where handset activation data is stored. Anyway, my own opinion is that the "possible loss of 3G" claim is likely to be complete BS - it is simply too hard to believe, as it is reported to occur to nearly every handset maker and model, independent of software version or (proprietary) bootloader.
If you see a signal down around -90 dBm or lower (more negative) where you work "out in the boonies", your battery life is being affected by how much power it is commanded to use by the nearest tower. A new ROM probably won't help as much as Airplane Mode in that case.
3G reception comes and goes in weak signal areas; the best way to test the phone is to take it someplace where there is a good signal and see if it reports "3G".
eu1
